Reuse crank gear w/ new chain?
This might be a dumb question but is there any problem w/ reusing the stock 30K mile crank gear with my new LS2 chain and adjustable timing gear? I put the new cam in tonight dot to dot prior to degreeing and the chain seems a little loose but then again I don't remember how loose my stock chain was before I pulled the cam out a couple days ago either.
Yank had some sets for sale a month or two ago (they might still). Anyways, it's basically a stock crank gear with an LS2 chain and an adjustable cam gear - the type with the dowel hole on the gear bored out a little so you slip in the different sized "rings" into the hole based on if it needs to be advanced/retarded or not.
