Disapointed in Dyno #s 408
Old 07-11-2009, 05:09 PM
RyanSws6's Avatar
Default Disapointed in Dyno #s 408
Mods in sig, finally got a dyno tune today, 455/455. I'm disapointed. Trust me the car is super fun to drive and a hand full, but from what I've seen here I expected at least 470. I was hoping for 490+.
Here's the story, couple things hurting HP:
My 342 rear was bad so I dropped in my 323. I've already ordered 373s.
My CNC Patriot2 heads?
Cam?
Unported 92 Fast
Hooker LTs 1 3/4s I think, non super comp. Thinking of TSP 1 7/8 LTs
I reached peak HP at 5800, a little flat to 6300. I'm ok with that don't want to rev to the moon, though I think it should still pull to 6300. Springs are the double HD good to .650.
Next week I'll have the new gears in.
I've considered ported L92s or Ls7s or more porting on the 243 Ls6 heads.
Fuel is good and timing was 33 max at WOT. AF was 12.5-12.7
Think it may be a combination of needing a custom cam, porting fast 92 and hooker LTs. This all may add up to 50 HP I'm missing...
My goal is 500 NA. So Those ported L92s and LSX int with 1 7/8 LTs should put me into the 500na range.
Old 07-11-2009, 06:52 PM
Red96TA's Avatar
Some larger primaries will open up some constricted horsepower, but not to the level youre wanting. Other factors come into play on that, hopefully someone who knows more than me will chime in on that.
Red96TA's Avatar
Also, dyno numbers are just that. Numbers. Track times tell the whole story.
Old 07-11-2009, 10:07 PM
Restricted User
2001 Pewter WS6's Avatar
That is about par for the Patriot heads. They are all pretty much in the 470rwhp range
Old 07-11-2009, 11:57 PM
RyanSws6's Avatar
Yeah been thinking that...I got those heads when I was planing a Ls6 build.
I just got the GM high tech issue with the section on 4.0 bore heads. I may do this along with the 1 7/8 headers.
Old 07-12-2009, 01:21 AM
LS1Silverado05's Avatar
Take it to the track....
Dyno numbers mean very little due to so many variances in dynos and other factors....
The track for the most part will give you a much better idea of how your car performs
Old 07-12-2009, 02:20 AM
ms4z28's Avatar
What's the torque at? And also is it auto cuz that will affect number but like they said it's just a number if you want a dyno queen get a supra
Old 07-12-2009, 02:25 AM
ms4z28's Avatar
Also is it a stock 10 bolt or a bigger
rear with those gears?
Old 07-12-2009, 11:39 AM
RyanSws6's Avatar
Not looking for a dyno queen. But my goal for this build was 500NA. I think you guys can understand that. I've been reading how dynos give different #s. Trying not to focus on the #s but hard not to when I didn't hit my goal.
Now need to decide if to rework the CNC Ls6 heads
OR
Buy AFRs or Trick flows
OR
Go Ls3/L92
Old 07-12-2009, 09:47 PM
Jimbo'sZO6's Avatar
[QUOTE=RyanSws6;11895943]Not looking for a dyno queen. But my goal for this build was 500NA. I think you guys can understand that. I've been reading how dynos give different #s. Trying not to focus on the #s but hard not to when I didn't hit my goal.
OR
>Buy AFRs or Trick flows<
Get the AFR's or TFS heads, port your FAST 92 and TB and you'll pick up that extra power you are looking for.
Jimbo
Old 07-13-2009, 03:27 AM
Nitroused383's Avatar
Try lowering your timing if you have 243 heads. They make best power around 22-26 degrees of total timing. If you did the L92 heads you would need a different cam as they work better with a lot smaller cam. What is your compression ratio and was the cam degree'd to the specified valve events?
Old 07-13-2009, 03:57 AM
venom ws7's Avatar
I have a friend with 408ci Gained almost 15rwhp in mid range and peak power from swapping a cam very similer to your to PatG Custom grind and after that he changed his 1.3/4 LT Headers to Kooks 1.7/8 Headers
Numbers were Like this 1st Run a4 408ci Similer cam and Patriot Stg 3 heads
made 466rwhp
Patg Cam with M6 Swap made 495rwhp
final numbers with PatG Cam, M6, Stg 3 Patriot Heads, Kooks 1.7/8 headers
a great 505rwhp 475rwtq
Get TSP Thire awesome , Talk to Pat about a cam, port your Intake
(talk to Ron@vengeance) and if you can change the heads
thats 500+rwhp setup right there for sure and BTW Your numbers are not that abd for the setup.
can you post a graph??
Old 07-13-2009, 05:32 AM
PREDATOR-Z's Avatar
I know how to make $$ in the US. Run a happy dyno, that is all poeple care about.
You see nothing in a dyno graph but the peak number
>I do not see a Ram air, if you are only running lid you are choking.
>1 7/8 headers, 10 or maybe 15rwhp
> cam is good, but if it peaks that early, degree it and retard it 2>4*
>what exhaust do you have? if Y pipe run cutout.
That should get you 30rwhp
Old 07-13-2009, 07:57 AM
1998Z28LOADED's Avatar
WORD
Old 07-13-2009, 10:05 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
For a cam that size to peak at 5800rpm, I'd start by rechecking the intake centerline it was installed at. That seems a good bit early (again, without knowing full details on the cam spec and VE's). And then get the rest of the combo up to par like the heads, intake, exhaust so the engine can breath in and out efficiently.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 07-13-2009, 03:24 PM
RyanSws6's Avatar
Matt, the cam I had ordered from John at the same time I ordered the 408. I will be ordering the 1 7/8 headers you guys have.
The peak is way too early. I don't think my tunner played with the timing much as we did 3 pulls.
I've been in several 500rwhp cars I saw on the dyno and went for a ride. I know exactly what I want NA.
It is a ram air with OE box, hood and SLP lid.
I want to get the 92 fast ported any recomendations?
Looking into this now...
Will install a cutout prior to the Y.
TSP 1 7/8 headers
Porting Fast 92
Further research: HEADS, AFR or TFS or reworking the Patriot 2s.
Catback is similar to my Borla on my LT1. Hooker Y into a resonator straight out the rear, then like in the borla SLP 2OTL. Sound is perfect! No rasp.
Old 07-14-2009, 01:14 AM
MASS seller approved
smok'nZ's Avatar
buy some heads that flow 320-340 maybe tfs 235's or etp 245's but patriot stage III's and a 24x-25x cam should be in the 500+ and with 1 7/8 i think 10-15 is what they will net you if you go true duals
Old 07-14-2009, 07:52 AM
RyanSws6's Avatar
Thanks, I just ordered the 1 7/8 headers and sold the Hookers. Now I'm working on the heads. From what I've been reading the cam I have should still net 500. Looking at bumping up compression from 10.2 to 11.5-8.
Old 07-14-2009, 02:28 PM
c0ncEpT's Avatar
I would seal off the lid and go to a GM 85mm MAF and 85mm lid also. Some TFS 225 or 235 heads would be nice too.
Old 07-14-2009, 04:22 PM
KCFormula's Avatar
......that and slow down the tach. If you don't have that much faith in your machinist is it worth the $1 savings? To make HP NA, you need RPM, thats all you got.
Quick Reply: Disapointed in Dyno #s 408
