how big SHOULD I bore the Dartons?
When doing a Darton re-sleeve, they say a max bore of 4.160".
What happens when you reach that point (has anyone done it)? Why not any bigger (are the sleeve walls thin at that point)?
I had planned to do a 4.125" bore but if I can go on up to 4.160" and it be SAFE (daily driver/road race motor), then why NOT do it?
Chris
Chris
4.125 will allow room for future rebuilds. You will be able to go up in increments, if you max it out right away, when something happens to the cylinder wall, or when it needs a bore/hone, you won't be able to do it, yo'll need a new block. Besides, the .035 bore that you'd gain would probably not help much in the power/torque department. Just my .02, though.
Shawn
Shawn
Originally Posted by 2001CamaroGuy
other than the rebore option, are there any negatives to the 4.160" bore?
