Patriot 243 Stage 2's showed up today
Old 07-14-2009, 03:19 PM
Intercooler2's Avatar
Default Patriot 243 Stage 2's showed up today
These are nice looking pieces! The flow sheet shows typical numbers listed on their site for 2.05/1.57 Stage 2 heads. They included the warranty sheet, head torqueing sheet and flow sheet. Should do well with the bump in compression to 11:1, FAST 92/92 and 224/228 cam.
Old 07-14-2009, 03:24 PM
The flow numbers are about equal to AFR 205's I think.
Attached Thumbnails Patriot 243 Stage 2's showed up today-img_0311.jpg   Patriot 243 Stage 2's showed up today-img_0312.jpg   Patriot 243 Stage 2's showed up today-img_0313.jpg   Patriot 243 Stage 2's showed up today-img_0315.jpg   Patriot 243 Stage 2's showed up today-img_0316.jpg
Old 07-14-2009, 03:47 PM
nocooler's Avatar
Nice...
I'll be interesting to see how it runs with the H/C/I.
Old 07-14-2009, 03:52 PM
allthrotle's Avatar
Im running the 243's with the 59cc chambers and put down some good power with them. My valve sizes are smaller though.
Old 07-14-2009, 04:17 PM
Those are good numbers! Trying to find the specs on your cam. I am in hopes of those numbers with my combo. Do you have track times?
Old 07-14-2009, 04:21 PM
allthrotle's Avatar
cam specs are 228/230 @.050 .585/.585 on a 112lsa. No track times. Im guessing somewhere in the 11's since I beat up on a 12.0 evo all the time.
Old 07-14-2009, 04:31 PM
DarkhorSe_SS's Avatar
I'm gonna go with the same heads.
Patriot Performance CNC Ported 243 LS6 / LS2 2.055"/1.57" 59cc Heads Assembled
What's the difference from your 2.05 and the 2.055?? Slightly bigger valves I'm getting
Nice numbers allthrottle
I'm going with the TV3 on a 111 lsa so hopefully my numbers are just as good or better. I do need to get the fast tho
Old 07-14-2009, 04:42 PM
99Ls1fever's Avatar
What Size combustion Chamber is on your heads 59cc?
What is the stock Combustion Chamber on a stock 853 head or 241?
Old 07-14-2009, 05:20 PM
66.67cc = 10.1 CR (stock LS1 head spec)
64.43cc = 10.5 CR (stock LS6 head spec)
Old 07-14-2009, 05:52 PM
These heads I am pretty sure are the 2.055 valved heads just called 2.05's.
I got the 64cc heads so with the .040" Cometics I will have 11:1
Old 07-14-2009, 05:54 PM
Originally Posted by nocooler
Nice...
I will have it at the track the minute all changes are done (doing a 92/95 since Speed Inc. failed on delivery) and 42's. The 9" goes in the 25th so I want to head down on just that setup all bolt-ons and see if I can pull an 11. Then on to making some serious changes and hoping to drop it to low 11's.
Old 07-15-2009, 11:00 AM
99Ls1fever's Avatar
Good info thanks. I dont see though how 2 twnths can raise the compression of the LS6 TO 10.5 though? It seems so little an insignificant.
This is what I got off Patriot Performance Website. "The 59cc head is just a milled version of the 64cc head. The 59cc will yield a .5 higher compression than the 64cc."
Also what size Combustion Chamber is the 5.3 Heads?
Old 07-15-2009, 11:39 AM
LSX Mechanic
Damian's Avatar
They definitely don't flow like AFR's, but Patriots are great for the money.
I did about 4-5 sets last year, and I saw a very consistant 30-35rwhp gain from them. The highest we saw was 41rwhp, but that was a 58cc head and thinner head gasket. Lots of compression.
Great heads for the money. If you could find a reputable porter to hand finish them for a good price, they're even better.
Old 07-15-2009, 03:58 PM
Bader-X's Avatar
1992 on the flow sheet ^_^ nice heads good luck
Old 07-16-2009, 06:47 AM
99Ls1fever's Avatar
Does anyone know what the stock Combustion Chamber size is on a 5.3 Heads?
Is it 59???
Old 07-16-2009, 11:27 AM
The 1992 number isn't the date. Actual date was 7/09. That's some other number... software I think
Old 07-22-2009, 11:15 AM
mtuggle86's Avatar
Is it 59???
Its think there 61cc
Old 07-22-2009, 11:21 AM
mtuggle86's Avatar
Is it 59???
Old 07-27-2009, 08:42 AM
Do you have any sound clips?
How much of a difference is this cam toward the Torquer v.3? I read about the spring issues with the torquer so I'm curious on your pick of cam. Nice numbers again.
Old 08-02-2009, 05:28 PM
Thule's Avatar
I got those heads, 226/226cam and fast90/nw90 and i am realy pleased, they are well made,
I got no dyno's but those heads woke my motor up,
