Full throttle ticking???
Old 07-16-2009, 10:11 AM
a.white86's Avatar
Default Full throttle ticking???
When I'm wide open, my 2000 SS makes a fast "ticking" noise.. Like, between 4000 and redline.. Something to panic about? I'm running premium fuel and everything.. So, what is it?
Old 07-18-2009, 04:40 PM
a.white86's Avatar
Nobody on this whole forum has any idea/?? Surprise Surprise! Thanks for the help!
Old 07-18-2009, 05:03 PM
99Ls1fever's Avatar
Valvetrain Noise, how many miles are on the car? Cammed?
Old 07-18-2009, 05:12 PM
BigRobSS's Avatar
If you're cammed I was told its common for a lot of valvetrain noise. Mine makes a similar noise, think its a lifter? I'm no mechanic so who knows....
Old 07-18-2009, 05:30 PM
OffspringZ28's Avatar
see if you can get a vid up. could be a bunch of things. is it more of a "ping" or is it a plain ol' tick? Check your rockers, 22 ft lbs i think. (Don't quote me on that number, search)
Old 07-18-2009, 06:16 PM
99Ls1fever's Avatar
I would tighten all of your spark plugs too, my buddy came to me one time with his Z06 and said he heard a ticking sound coming at high rpms. We started the engine up and threw a light down there and came across a loose plug that had just rattled loose. Problem Solved. Sometimes it is just the little things
Old 07-18-2009, 06:23 PM
02*C5's Avatar
I usually get the ticking when I start the engine, its cold and the oil is starting to move through the equipment. Once though I am at operating temp am good so the thing is;
what oil are you using? Second
what type of MODS do you have?
If you have mods did you change the oil pump for a ported LS6 or a Melling product.
Also it would help us give you better advice if you posted mods and such not just throw a bone, then wonder Y ur not getting answers.
Old 07-23-2009, 01:22 PM
a.white86's Avatar
Well thing is, there are ZERO mods on the car. Nothing has been touched EVER on the car! No heads, no cam, no nothing. No exhaust, intake, nothing. I heard that its probably a rocker though. Is this a big deal? I may try and get a video up of it but I doubt you'll be able to hear it on video.
