LS1 Cam Gear, Cam Swap
I am going to be doing my cam swap this week, I haven't done a cam swap yet so this will be a good learning experience.
I currently have a stock timing set with a LS2 timing chain, the new cam I am getting is a 113LSA+4. Will I be able to degree the cam with the stock cam gear? If so how? Or do I need to look at getting an adjustable timing set?
Thanks.
Thanks.
yes, they are dots actually, cam (top) dot will be at 6 o clock and crank (bottom) dot will be at 12 o clock. Some here will tell you that you should degree the cam.
