Any news on the L92 small bore heads?
Old 07-20-2009, 05:15 PM
99Ls1fever's Avatar
Default Any news on the L92 small bore heads?
A couple of months ago GM High Tech Performance got great results with the L92 heads on an LS2 (I believe it was a 44 hp increase). In the same issue they mentioned a small bore version was in the works for the LS1/6. Does anyone have any new info, possible release date, etc.? At around $800 for an assembled pair, these would be a great deal compared to Trickflows, AFR's, etc, if they offered the same increase for the LS1/6.
Old 08-18-2009, 12:38 PM
99Ls1fever's Avatar
Bump, I have been trying to find some info on this and the best I have found so far is RLD Performance.
http://www.rldperformance.com/catalog.htm
Old 08-18-2009, 03:15 PM
socal's Avatar
i wouldn't hold your breath for gm to make them but i think Mast out of FL has there own version
Old 08-18-2009, 08:12 PM
99Ls1fever's Avatar
Yeah Mast does the LS3 heads but they are 1,200 bucks un-assembled each!!! Ouch! I know RLD Makes the L92 heads but was looking for someone with personal experiance with these setups. RLD on there web page and through a PM from a fellow LS1 Tech persons says they make the small bore L92 Heads. I just wanted some one with knowledge on this topic to chime in and give there 2 cents on the heads and the idea of the conversion.
Old 08-25-2009, 07:57 PM
prostock_bigblock's Avatar
I would recommend you talking with Stan from RLD. I know he makes the chamber for any bore you want small, big..
Just because no one here on Ls1tech has experience with these heads, doesn't mean its a bad product.
Old 08-25-2009, 08:52 PM
99Ls1fever's Avatar
Yeah, I just wanted to see info on numbers put down and the pricing and if the pricing above That I posted is correct.
I really am thinking about going this route on my ws6 once my 99' Camaro gets out of the shop.
Old 08-26-2009, 05:59 PM
Peetyz's Avatar
get a chance to talk to rld? those look like nice flowing heads! im looking at prc stg 2.5 5.3's but these also caught my eye
Old 11-03-2009, 05:34 PM
Johns00Z28's Avatar
I talked to Stan today and he said they were $1900 assembled for the pair.
