Got estimate for 383 from local machine shop can someone pick it apart PLEASE!!!
I have an sts with t67 and fmic. here is the estimate I recieved from local shop can you help me pick it apart as far as parts, also is labor reasonable.
Parts
Wiseco 3.903 -15cc Dish Pistons w/ File to Fit Rings 770.00T
K1 Technology 6.125 Connecting Rods 550.00T
ARP Main Studs 230.00T
Durabond Cam Bearings 30.00T
Clevite H Series Main Bearings 110.00T
Clevite H Series Rod Bearings 65.00T
GM Press in Oil Plug, Oil Dumbell Plug 16.00T
K1 Technology 4" stroke Crankshaft 780.00T
Labor
Dissassemble Short Block 125.00
Hot Tank Shortblock 115.00
Toque Plate Hone Cylinders 225.00
Align Hone 185.00
Balance Rotating Assembly 185.00
Assemble Shortblock 400.00
Deck Block Square 150.00
FL & EXC County Sales Tax 191.33
$4,127.33
Parts
Labor
Align Hone 185.00
$4,127.33
with 4k you can get a 408 and resell ur current engine or shortblock and make some money of of it and save a bit for the 408
Parts
Labor
Align Hone 185.00
$4,127.33
Parts
Labor
Align Hone 185.00
$4,127.33
Thanks guys I believe Ill still use my block haggle a little labor out of them and it would be fair. Im just not going with there parts just might buy tsp rotating assembly 383 and take the optional upgrades for the better rings and -15cc pistons. for like $1750.00 and not pay tax thru online so in all I save about 400 or more off the estimate.. So what you think Imm ready to get this over with spend my load and get back in my ride...
Heres what im looking at and taking the upgrades comes out to 2200 on parts and then let him do the block work and tell him assembly around 200 seems fair..
http://www.texas-speed.com/shop/item...d=884&catid=88
for everyone saying 383 isnt worth it FWIW my 383 makes 500rwhp NA and ways 100 lbs lighter than an lq9 408 if your going with a blower, turbo or spray over a 200 shot in the future go with the 408 if not you really dont need an iron block just more weight on the nose of the car which makes it turn like a pig. my buddy had a 408 in his SS made about the same maybe a little less than my motor cars were almost even HP wise. both cars were M6s and we both had moser 12 bolts. my car would easily pull 5 to 6 cars on him in a quarter mile. my car hooked up better and pulled harder. he ended up flipping it like 5 times on a back country road when the *** end came around on him while taking a corner. if your shooting for over 700rwhp FI in a drag car than go with the 408.
for everyone saying 383 isnt worth it FWIW my 383 makes 500rwhp NA and ways 100 lbs lighter than an lq9 408 if your going with a blower, turbo or spray over a 200 shot in the future go with the 408 if not you really dont need an iron block just more weight on the nose of the car wich makes it turn like a pig. my buddy had a 408 in his SS made about the same maybe a little less than my motor cars were almost even HP wise. both cars are M6s and we both had moser 12 bolts. my car would easily pull 5 to 6 cars on him in a quarter mile. my car hooked up better and pulls harder. he ended up flipping it like 5 times on a back country road when the *** end came around on him while taking a corner.
The main advantage to a 400+ inch motor is the 4.0X bore. You can get much better flowing heads.
If given the choice between a 383 LS1 motor, or a 370 LS2 Motor, i would pick the 370 every time because of the larger bore.
Moderator
Then dont use an iron block on the 408. Build an LS2 based motor.
vipvegas:
As far as parts go, the pricing is good. You could find cheaper parts, but the K1 stuff is pretty nice and Wiseco is top notch. With the machine shop being local to you, if you have a problem with the engine, shipping won't be an issue in getting it fixed. Ask some people who mail ordered their engine, and they'll tell you the same. Good luck with the build, and keep us posted.
He's going to be cramming air in via turbocharger, so all of that kind of goes right out the window.
vipvegas:
vipvegas:
If i were the OP, i would build a stock stroke motor instead of a 383. It would be cheaper and handle the power just as well.
LS1Tech Premium Sponsor
Not to nit-pick that, but we offer it with the Callies Compstar crank and rods, Mahle pistons and rings, bearings and balanced for $2379.99. Their site has it for $2388.99
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
your not comparing apples to apples. how big is your cam? how big is his? what kind of heads you have? what kind of heads does he have? what do they flow? what are the supporting mods on both cars? weight reductions on any car? does he know how to drive? the 408 can make more power period.
true i had my 383 when 408s werent around but i did build my top end up after he had his built so i prolly got better top end parts parts, other than that the cars were identical in fact he had 4.10 gears i had 3.73's. its weird i see some people with 408s making over 520 at the wheels then i see some that making less than 470 at the wheels, its really all in the motor setup you can make more with a 408 if you build it right. the next motor i will be building will be a 414 with twin 67's just gotta get my money right.
agreed. most people just slap parts together and bitch and cry about why they didnt get the same amount of pwer as the other guy. its all in the parts an dmatching the heads to the cam. that why a custom grind cam is the way to go. tony over at afr can grind custom cams for his heads. obviously hes knows what makes his own heads move. when i get my 427 ls1 mid darton block assembled. i will be going with tonys new 245cc afr heads and a custom grind cam. should be good for all day 10s and with some weight reduction and slicks high 9s is a possible dream. the best advise i can give to the op is do research on parts and combos. dont mismatch ur stuff. you can have the best flowing heads on the market and a cam that is meant for l92 heads, then you wont get what the results you want.
