Oil Filters
Old 11-18-2003, 05:06 AM
00T\A's Avatar
Default Oil Filters
Hey Guys do anyone know the differance between the AC Delco PF58 & PF59 oil filters?
I have been running the PF58 for a long time because it is longer ,Now they have a PF59 Anyone know the differance?
Old 11-18-2003, 09:00 AM
bryan c's Avatar
The PF59 has an anti-drainback valve, the PF58 doesn't. I think the PF58's have been discontinued. SDPC sells the PF59's for $2.39.
Old 11-18-2003, 09:06 AM
Fulton 1's Avatar
That's my understanding as well (no antidrainback valve on PF58). Either will work fine on an LS1 since our filter mounting position does not require the valve. Maybe Patman or someone over at bobistheoilguy.com can confirm...
Old 11-18-2003, 10:07 AM
00T\A's Avatar
Thanks Guy's That what I needed to know.
Old 11-19-2003, 03:53 AM
Patman's Avatar
It's true, the 58 has no ADBV. It is not totally necessary, but it still helps you get faster oil flow on startup, as it holds the oil above the filter on shutdown. Without the ADBV, this little bit of oil (about 100-200ml) would not stay there, it would flow back into the pan.
Old 11-19-2003, 03:55 AM
JMBLOWNWS6's Avatar
Get a k&n oil filter you will not be disapointed
Old 11-19-2003, 04:56 AM
00T\A's Avatar
Hello Patman Thank's for the reply.
I have another question Is the K&N That much better than the GM PF59?
Money is not an option When it comes to T\A's Blood.
Thank's in Advance.
Old 11-19-2003, 07:54 AM
Patman's Avatar
The K&N is definitely better than the AC Delco, it will flow considerably more oil. Oil flow is the most critical function of an oil filter on a hard driven high horsepower car.
Old 11-19-2003, 08:16 AM
00T\A's Avatar
Thanks Patman an thanks to the rest of you guy's for your responces.
I will be Switching To K&N on my next blood transfusion.
