706 heads on 6.0 Compression ratio?
Old 08-07-2009, 03:54 PM
velox65's Avatar
Default 706 heads on 6.0 Compression ratio?
Ok Im putting some ported/polished 5.3 706 heads on my lq4, what compression ratio should I be expecting from this? I searched but to no avail I found nothing.
Old 08-07-2009, 06:12 PM
novaflash2002's Avatar
well with a .051 thick gasket, 4.045 bore gasket, 4 inch bore, 7cc dish piston, piston set out of the hole .003 inch, and 3.622 stroke, and a 62 cc chamber it will be 10.431:1
Quick Reply: 706 heads on 6.0 Compression ratio?
