scattered motor, new plans
Old 08-11-2009, 02:45 AM
2001ws6-500hp's Avatar
Default scattered motor, new plans
scattered my motor the other night at 6700 rpm. wasnt too fun. i know this sounds crazy but the 2nd and 3rd rods from the front of the motor let loose and completely wiped the block. the rods took out a section from about the bottom of the motor mount down the side clear to the bottom of the pan, across the bottom and up the other side. its insane. i think if the heads werent on it, the block would be in half. but i need to know what i wanna do. i either want to build a iron block 408, or just get a stock ls1 block and fill it with forged internals and then spray like a 200-250 shot on it. what would u do?
Old 08-11-2009, 02:49 AM
BAMF's Avatar
418 ci built with a 2009 LS3 block
Old 08-11-2009, 09:40 AM
tator98ta's Avatar
408..Big cubes=big fun
Old 08-11-2009, 09:45 AM
KCS
Moderator
KCS's Avatar
370ci iron block and nitrous. For the money you'll spend on a forged crank, you can make more power with spray. Just my $.02
Old 08-11-2009, 10:09 AM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
without a doubt I'd look to the 408 iron blocks for a great buget short-block. We stock tons of these things with different rod, piston & ring combos. I bet we have a setup ready for 200+ shots in stock & ready to roll. Let me know if we can help you out with one. We also stock 370s typically, but your within a few hundred bucks of the 408, you'd just about be crazy not to take the extra cubes for the little bit extra $$$$...
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 08-11-2009, 10:53 AM
TooLateVTEC's Avatar
408 no doubt, damn the nitrous unless you already have it.
If you do already have it...oh well, I still say 408 lol.
Old 08-11-2009, 01:23 PM
conan's Avatar
One more for the 408ci, and post up some pics of that ****
Old 08-11-2009, 02:32 PM
99blancoSS's Avatar
408 all the way for best bang for the buck. We offer HKE precision racing engines if your looking for a built short or long block or can set you up with a rotating assembly if you prefer.
Old 08-12-2009, 09:27 PM
Juicedh22's Avatar
why am I not surprised?
Old 08-12-2009, 10:03 PM
xxtheonlyxx's Avatar
How many miles were on the block? The carnage is not typical for a high 11 second LS1.
Old 08-12-2009, 10:42 PM
MelScrilla's Avatar
I would do the 408 if you can afford it but then on a budget a 347 with a lot of spray would be fun.
Old 08-12-2009, 10:51 PM
will post pics this weekend when the motor is pulled
Old 08-12-2009, 10:52 PM
why are you not surprised? i dont even know who u are??? wtf
Old 08-13-2009, 05:26 PM
spaulsen's Avatar
do you have video of how it happened joe? dude, do a 416, ls3 block, stroker crank ect....put a D1SC procharger and have lots of hp! you wont be dissapointed!!!!!!!!!!
Old 08-13-2009, 05:49 PM
SLOC5LS6's Avatar
were you spraying? what were your mods to do that much damage?
Old 08-15-2009, 05:10 AM
wasnt spraying. we pulled the motor tonite, broke the block about 3 inches up on both sides and clear down both sides of the pan, 2 pistons disapeared, 3 rods were broken, and one bent about 10 degrees. it was basically heads and cam car, lt's, intake,car made around 400, but new setup will be higher compression, around 11.3:1 with a whole lotta n2o.
Old 08-17-2009, 10:22 PM
spaulsen's Avatar
NOS is for people that have a hard time getting it up, and keeping it up.....
Old 08-18-2009, 12:05 PM
SLOC5LS6's Avatar
Do you know what caused the chaos?
Old 08-18-2009, 01:48 PM
thinking it was a spun bearing, which made the ptv clearance in the negatives, lol, but u can tell the valves were hit slightlly
Old 08-18-2009, 01:53 PM
LS1Tech Sponsor
hellbents10's Avatar
Spun bearing will not change PTV clearance. Sounds like the valves were floated and maybe started the disaster.
