Here we go out from the top LS1 to LQ4
Old 08-16-2009, 09:38 PM
CroonerSS's Avatar
Talking Here we go out from the top LS1 to LQ4 update!!!
Well, I decided to start pulling my engine apart today. Many people say it's a hard task and major pain pulling the engine out of a f-body. I would have to disagree with them. Its going pretty well for me and very simple. I started today at about 2:30pm and quit around 8:15pm. I was able to get one head off. Tomorrow I will have the second head off. Left the A/C, brake lines, and power steering connected.
I'm going back with a 6.0 iron block setup which should be alot of fun. Anyways here are some pics of today's work.
Old 08-16-2009, 10:12 PM
pauls99z28's Avatar
Looking Good man. keep us all posted with this build.
Old 08-16-2009, 10:52 PM
KING Z28 HAWK's Avatar
Looks like some one is having some fun. Good luck keep us posted. Whats the new set up going to be?
Old 08-16-2009, 11:36 PM
SchuttsR1's Avatar
Are those MN license plates I spy? Im doing the same as we speak but the frame is coming out of mine.
Old 08-17-2009, 07:13 AM
500@10psi's Avatar
I just got done doing this exact install last winter the only thing i havent done is the relearn but all summer with no issues. great for an extra couple of ponies and more FI friendly gl op keep us posted
Old 08-17-2009, 07:23 AM
CroonerSS's Avatar
Texas!
6.0
fast 90/90
comp lifters / push rods
ported 243's
custom cam around .600 lift 111lsa
ls6 ported oil pump
long tubes
Old 08-17-2009, 08:38 AM
V3NOM GTO's Avatar
where'd you pick up your bottem end???
Old 08-17-2009, 09:36 AM
cutlass_455's Avatar
You are probly going to have to drill and tap that boss out for the alternator bracket on that truck block. Ive circled it green in the pic. Use the bracket as a guide, and place a drill bit in the hole so its snug and give it a tap with a hammer to show you the centre. Then drill it out for a 10mm bolt and tap it.
Snowblind.'s Avatar
i have to agree with you that its pretty easy. pulled two heads off in a 4-5 hour time with two guys. we didnt pull the motor but prob will be soon seeing how its all kinds of messed up now. keep posting pictures
Old 08-17-2009, 10:00 AM
PREDATOR-Z's Avatar
If the block has 2 bolt for alternator, no need, been running mine with 2 bolts for 3+ years, on/off track and DD. No issues, never even had to retighten.
Old 08-17-2009, 07:26 PM
CroonerSS's Avatar
Bishops Dallas Tx
Old 08-17-2009, 07:59 PM
CroonerSS's Avatar
[QUOTE=lizy.lin;12086053][URL
SPAM!!!! get out of my thread
Old 08-17-2009, 08:02 PM
blk00ss's Avatar
Pulling the heads is a lot easier when you get the motor out BTW...
Old 08-17-2009, 10:15 PM
LS1Formulation's Avatar
Dropping the engine is WAY easier than pulling it out of the top. Especially because you can torque everything easier, attach the entire wiring harness outside of the car, and it makes it far easier to clean your engine compartment. When I just put my engine in last week, it took all of 30 minutes to take it from sitting on the floor to having it bolted in the car. I know everyone likes to do things differently, but after seeing it done both ways, I will NEVER even consider taking it out the top. Good luck on your project though, sounds like she'll be a beast!
Old 08-17-2009, 10:59 PM
CroonerSS's Avatar
next time I might try from the bottom just to see
Old 08-21-2009, 11:14 PM
CroonerSS's Avatar
Default Update!
I was able to work on my car again tonight. I got about 3 hours in tonight.
Got the drivers cylinder head off. Make sure you pull off the exhaust header first makes it much easier to get to the lower bolts.
Took both exhaust headers off. Dropped out stock y pipe.
Removed starter, pulled out most of the air and emissions crap.
Engine is ready to be removed. Just going to unbolt it from the bell housing and pull it out tomorrow. Then pressure wash the engine bay.
Got block ready to primmer then paint chevy red
Old 08-22-2009, 08:13 AM
01ssreda4's Avatar
nice work so far!!!
Old 08-22-2009, 08:52 PM
CroonerSS's Avatar
Got the engine removed today. Also, decided to prime and paint my engine block.
Tomorrow I will detail out the engine bay.
Old 08-22-2009, 09:52 PM
MattxFatal's Avatar
Damn dude, looks really good.
Keep us posted!
-Matt
Old 08-23-2009, 10:03 AM
HitmanLS1's Avatar
nice work so far
Quick Reply: Here we go out from the top LS1 to LQ4
