What is this???? (pics included)
Old 08-19-2009, 11:19 AM
Banging some gears
greyghost4x4's Avatar
Default What is this???? (pics included)
just above the WOT switch is where it is going into the intake....
closer up... you can see the cracks in it..
and here is the rest of it running along side the valve cover to the left of the fuel rail...
anybody know?
Old 08-19-2009, 11:26 AM
BIG_MIKE2005's Avatar
Looks like the PCV hose to me. I had a hole in mine right in there & it was causing a vaccumm leak which caused the car to idle wierd & die at stop signs sometimes. Replaced the hose & everything went back to normal.
Old 08-19-2009, 11:32 AM
conan's Avatar
X2
Pcv hose, you can fix it with fuel hose from any auto parts store. "Big mike" is right, it will or is causing a vac leak.
Old 08-19-2009, 11:37 AM
6th gear's Avatar
PVC hose
2001SS_stompinsupras's Avatar
as posted above it is the PCV hose, fuel hose from any auto parts store would work
6th pvc, are u sure it's white plastic tube? just kiddin
Old 08-19-2009, 11:39 AM
EndlessSummer85's Avatar
Yep I'd buy a catch can it'll clean it up and replaces most of the pcv hoses.
Old 08-19-2009, 11:46 AM
01ssreda4's Avatar
Thats exactly correct. Pull it and grab some fuel line from the auto parts place and slip it inline where the cracked up piece is.
Old 08-19-2009, 11:55 AM
kinglt-1's Avatar
I would check all vacuum lines. If one is cracked, most likely there are more in the same condition.
Old 08-19-2009, 01:29 PM
Banging some gears
thanks... i tell myself i know things about the ls1 but apparantly not.. still learnin
