roller rockers with g5x3...
Old 08-24-2009, 05:59 PM
Phantom's Avatar
Default roller rockers with g5x3...
how many of you actually uses true roller rockers? i currently have the g5x3 cam wit some roller rockers and patriot extreme springs...i'm thinkin of switching back to my stock rockers...ok move or not?
Old 08-24-2009, 08:03 PM
Kurtomac's Avatar
what heads and rockers are you using now?
Old 08-24-2009, 08:07 PM
waterbug1999's Avatar
ive been running my stock rockers with my x3 no problem.
Old 08-24-2009, 09:48 PM
Phantom's Avatar
there just some cheap shaft mount roller rockers. i just remember reading in gmhtp about stock rockers breaking with those real heavy springs
Old 08-25-2009, 04:38 AM
vettenuts's Avatar
Comp has a new trunion/bearing upgrade. If you return to stock you may want to pick up a set before putting them back in.
Old 08-25-2009, 05:18 PM
Minshall's Avatar
Im running the G5X4 on the stockers with no problems for me.
Old 08-25-2009, 06:04 PM
SOMbitch's Avatar
Harland Sharp will upgrade my stockers when my motor comes out....
Old 08-25-2009, 06:13 PM
JFM-jr's Avatar
I've run 20K miles with a G5X3 and an X4 combined on stock rocker arms GM 5.3 castings without any trouble. The real upside to a roller rocker only comes into play when somebody takes the time and does the research to set them up PROPERLY for correct wipe. This prolongs valve guide lifefor the softer aftermarket heads guides. If you just tossed a set of roller rockers on your heads chances are they are not centered on the valvestem. For those running a GM head it's hard to beat the stock rocker arms Harland Sharpe offers a trunion upgrade kit as well.
