lifter noise
Old 08-25-2009, 08:45 PM
camarozl1lover's Avatar
Default lifter noise
Hi guys. 1st post with a question.
I have lifter noise after a heads and cam swap. They are TSP 2.5 5.3L heads, .040 gaskets, cam is a 224 224 .600 .590 114lsa Oil pressure is 65psi at start, noise loudness increases as rpms increase. Currently running a 7.4 pushrod which is too long I feel. pulled a valve cover while running and there does not seem to be much oil coming from the pushrods, which makes me think the lifters are not getting oil, The oil o ring was installed correctly, would not have 65psi otherwise. would a push rod thats too long cause the lifter to not retain oil and thus cause a clacking noise? and also cause not much oil to come up to the top of the valvetrain.?
Thanks again, James.
Old 08-25-2009, 09:36 PM
AW794's Avatar
I feel a pushrod length checker is in order. When you installed the h/c did you bother swapping to LS2 lifter trays? Ive never heard of a pushrod not oiling properly because it was to long. Sounds like theres another issue at hand
Old 08-26-2009, 08:09 AM
bigboykilroy's Avatar
You need to check your PR length and lifter pre load first.
Old 08-26-2009, 09:27 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
Welcome to the board! Do you know how much your heads are milled?
http://texas-speed.com/shop/item.asp?itemid=913
That'd be your best bet to get the correct length. We can all guess at it all day based on experience, but at the end of the day there's enough variance there that you really should measure it and save the headache
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
