Patriot drop racing springs
We have a new spring for the LS1/LS6 engines.The spring is a drop in design.The spring is made for Patriot Performance,it is ours exclusively.The spring has 135 lbs @1.800 and 380 lbs open.The max lift is .650.It is made of the finest materials available.It has been electro polished to remove any stress in the wire.They have a nice gold color.
I'll be trying a set of these out on the latest LS6 style heads. I'll be installing the heads Wednesday or so and try to dyno either Friday or one day next week. I was having nightmares about one of my 918's taking a dump, so I thought these would lessen my stress level.
Originally Posted by v8maro
These are a true dual spring and a dampener rated to .650 lift?
-Steve
-Steve
Steve,
The springs are just dual,no damper.
Originally Posted by TVWilkes
The Springs are a dual spring.It has to use our Titanium retainer.The spring & retainer combo is priced at $265.00 .
cam. what else would I need besides your combo?? new seats, guides?
I am sure I will need better pushrods.
Thanks,
pete
Patriot Spring
Can you get a closeup shot of a spring? I'd like to take a lookie.
thanks
-Steve
thanks
-Steve
Steve,
Here is a closeup of the spring.
Originally Posted by 9T9BlueTA
wow that looks like a nice price. How do these differ from the Comp Cams 26921 kit that goes for $560?
They look like the same spec but half the cost .
I'm not sure how they compare to the comp 921 spring.Both of the springs have close to the same pressure.All I know about the comp is what they have published,I have never seen one of them.
As far as how long they will last.The spring manufacturer tells me,in his opinion,it will last better than the others on the market.The materials ans process used to make it is the same used to make Pro Stock drag springs.
Patriot Drop In Springs
Originally Posted by ssheets
Terry, will these be an upgrade option for the 5.3 stage IIs?
If so, how much $$ as an upgrade?
Kudos to Patriot for bringing another option to the LS1/LS6 aftermarket.
Will these springs require the special care most of the currents aftermarket springs do such as keeping under 2000rpms until full warm up?
Are aftermarket lifters required with the 380 spring pressure?
Thanks
Thanks
