Cam for stock heads
Cam for stock heads
Money is a little tight but was going to get a cam and LTs with my income tax return. What would be the best cam for these stock heads? Will get new springs and pushrods as well. Heads would be a few years down the road. Any thoughts?
Well seeing how my plans have changed (finances) I want the car noticeably faster than it is. Figured that a cam and LTs would make a good difference in it. Was just weighing my options as to what cam seeing how I will be replacing the heads in a few years.
LS1Tech Premium Sponsor
Give us some more details on the vehicle and its mods and plans. What do you do with the car (street vs track)? What specific goals do you have for this swap (sound, peak dyno numbers, street manners, etc)? The more specific you can be, the better the recommendations will be as to which route you might go.
We've got a little of everything from mild to wild, but need to know the details to make that recommendation!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Only mods I have are what show in my signature. K&N, Diablo sport II reprogrammer and a cutout. I have koni 4/4 on it too. My car is a street car. Might see the track later on but for now it is only for the street. I use it to go to work and back and some weekend drags on 82nd. I want good street manners and a great sound. Dyno numbers are a good thing but not the highest on the list considering it is on the street. This is my first LS1 so I want to do it right. Car has about 42000 miles on it. Seeing how yall are about 10 minutes from me I will be getting my stuff from yall. Just doing some research to see where I stand.
Right on, I didn't notice you were here local! Is your car automatic or a 6 speed? Are we going to tune the car or are you trying to use the Diablo after you get the cam installed? Are you keeping the stock exhaust and LS6 intake on the car or upgrading down the road?
__________________
I'd check out the 228R! It offers a nice mixture of peak power with nice street manners and power under the curve. It would be a nice addition to the car. I'd sell the Diablo to pay for a dyno tune!
__________________
The Torquer V2 is a good cam so is the 228r I don't think you could go wrong with a bolt-on street cam only car with either of those two cams. What clutch do you have stock? After the cam you'll probably want to upgrade if you haven't already. And LT's and a ORY are a prerequisite some will say before a cam even goes in. GL!
Also don't forget the little things your going to need such as gaskets, etc. I don't know how many miles are on your car but since your going to have it all off an Oil pump wouldn't hurt. Out of those 2 choices I would run the Torquer 2. I run the Torquer 3 in my car. Does fine on the street. I don't drive mine everyday.
