What can I gain w/ TFS heads
Old 09-05-2009, 09:20 AM
nickolbag's Avatar
Default What can I gain w/ TFS heads
My motor is a 383 ls6. Ported ls1 heads, 230/234 .592/.598 116. All the bolt ons.
This is what it made on the dyno..............
If I kept the same cam, what do you think I can gain from swapping the ls1 heads for TFS 225s or another head in that league?
If I go with a bigger cam along with the better heads what kind of numbers are reasonable?
Old 09-05-2009, 04:42 PM
teke184's Avatar
for a 383...i'd stick with the tfs 215s
they flow well enough to make GREAT power under the curve and up top.
do you have a FAST?
Old 09-05-2009, 07:15 PM
garygnu65's Avatar
20-40 rwhp ,afr 205 ,tfs 220 as cast flow close to each other.
Old 09-05-2009, 11:59 PM
MelScrilla's Avatar
I'm with him. A fast will also flow the amount or air that those heads want to.
Old 09-06-2009, 12:52 AM
transamfreak01's Avatar
prc 215s ftmfw!! they are cheaper than trick flows, out flow then (not by much but still) and you can keep your stock rockers unlike trickflows so thatll save you an additional 450 right there. i started a thread and a few people put some links on there. they made over 450rwhp with a cam just like yours. one guy actually made like 470 or 480rwhp and that was on a 346
Old 09-06-2009, 01:00 AM
Detoxx03's Avatar
If your gonna do it I would get a FAST
Old 09-06-2009, 09:41 AM
nickolbag's Avatar
Yes I have a Fast 90 right now.
I want to make a minimum of 470 if I do a head change.
Old 09-06-2009, 05:00 PM
yes you will make that. if the 346s are i dont see why youre 383 wouldnt
Old 09-06-2009, 07:25 PM
WSsick's Avatar
i think the 215 will suffice, although personally i havent seen too many 225 combos to speak about those. might as well get a new cam spec'd for the new heads while youre at it. maximize your combo and you could see 500 easy. combination is the name of the game. from your current cam id guess that you want a very well mannered street friendly cam, correct? thats still possible, even if you bump up the specs. the extra cubes will help eat the extra duration, and keep it on minimal overlap and youll be fine if I went for a 383 with big heads & a FAST, id like something in the 24x/24x range, but tahts just me.
what kind of compression would you be shooting for? would you like lwoer, or go with a milled head and/or gasket for a little bump? that would also allow you to run a slightly bigger cam and still be mild mannered.
Old 09-06-2009, 11:52 PM
fatmat80's Avatar
Thumbs up
25-45 for sure by adding the heads..but i would have to agree i would step the cam up just a bit as well..
Old 09-07-2009, 10:31 AM
nickolbag's Avatar
I believe I'm around 11.8 right now. I would shoot for around that with the new setup.
Thanks for all the input guys.
Old 09-07-2009, 10:43 AM
litle88's Avatar
Mods are in my SIG and that HP is on a mustang Dyno, I am using a set of TF as cast versions and love them, I think they are the best bang for the buck right now. Call Vengeance they usually have them on sale. I think you should be making more than 447 hp? Who did the work? Could you be off a tooth? Just my .02
Goodluck!
Old 09-07-2009, 10:44 AM
LSX Mechanic
Damian's Avatar
JMO...
I don't think you're going to gain 40 more rwhp over an already ported LS1 head w/ a TFS 215. First being that we don't know how well those heads are ported. Your motor is making great power, that TQ curve is great. Do you have any specs and/or flow #'s on your current heads?
Last thing. If the valvetrain is not set up perfect, your power fall off way too early. It takes a lot of attention to detail to get the rockers set up on these heads. DO NOT order the Trick Flow pushrods with the heads, they are almost always the incorrect length. This should be the last thing you order after you measure.
Old 09-08-2009, 01:57 PM
nickolbag's Avatar
Goodluck!
Myself and Cartek did the work.
Originally Posted by Damian
JMO...
Cartek did the head porting and I do not have flow numbers. Will even a great set of ported 241s keep up with the demand of a stroker?
Old 09-08-2009, 03:46 PM
SOMbitch's Avatar
Let me know if you wanna get rid of those heads (PM). I might be interested........
Old 09-09-2009, 05:03 AM
Ron@Vengeance's Avatar
nickolbag,
We have several members on this forum with 383s making excellent power with TFS heads... 9secondsflat runs our VRX5/TFS 215 combo and is making OVER 500RWHP/500RWTQ with excellent street manners.
Depending on when/who ported your heads I would say there are definately gains to be had going with the TFS cylinder head.
As Damian suggested, if the valvetrain isnt set up properly you will see power fall off early. Fortunately this isnt specific to TFS heads. It is engine building 101 for ANY valvetrain you are assembling
Give us a call if we can help you out. We are currently offering 150.00 off roller rockers with the purchase of TFS cylinder heads.
Old 09-09-2009, 09:36 AM
Slow 346's Avatar
Originally Posted by Ron@Vengeance
nickolbag,
Give us a call if we can help you out. We are currently offering 150.00 roller rockers with the purchase of TFS cylinder heads.
What rockers are 150.00 with purchase?
Old 09-11-2009, 01:16 PM
9secondsflat's Avatar
look at the torque curve on the tfs...its a flat line...i have a 383 also...get the heads a decent cam....and you should be well over 500 rwhp...i made 532/472 on the vette dr's dyno ... the car idles perfect..no surging, bucking...i can drive the car down the road at 1300 rpms and dont have any problems. my car has run side by side with a new zr1 from 30-150...he could not pull me. check out the vids... http://www.youtube.com/watch?v=KAB1H4F5pvs
Old 09-11-2009, 02:49 PM
transaman98's Avatar
nice...damn stock cars and all their power make me feel bad...
Old 09-12-2009, 12:27 PM
69_YENKO's Avatar
Not 150$ for a set of rockers, they are offering a 150$ discount off the price of the rockers with a head purchase. not a bad deal at all
OP, the TFS heads are for real. I made almost exactly the same power as Litle88 with my with my TFS215's. I want to say mine and Litle88's cams are almost the same as well. I dont know what compression hes running but I was at 11.1 and through an auto.
Quick Reply: What can I gain w/ TFS heads
