What cam to get
What cam to get
I have a 00 trans am and i had a gm hot cam in it but my motor messed up and i was forced 2 get a new motor so now im wonderin what is the best cam out there 2day. I want somethin that lopes a lil better than my gm hotcam cuz it barley loped and i want somethin more aggressive. please respond Thanks
i'm curious, how does a motor "mess up"?
i heard that the hotcam had 1 of the bigger lopes of all cams, and urs barely loped??
i hafta ask the basic questions, M6 or A4? tuning? bolt ons? headers?
just about any cam on a 112 should lope pretty good...
SN95 Director
Originally Posted by Cal
You can make any cam lope more or less by how you tune the PCM. Try a TR230 or X1 on a 111 LSA and set the idle at 600, take out a couple degrees of idle timing and you should have a motor that almost rocks itself of it's mounts.
the motor messed up because it through a rod. And since i am gettin a new motor and stuff i was wonderin what cam like added the most. I didnt know u could set the cams to lope more or less i just got the car.
Thanks guys. on that tsp cam does it come with a kit like the hotcam with new valve spings and rods or do i need to buy some that are compatible with that cam? Thanks
!LS1 11 Second Club
Call TSP, they'll hook you up w/ all the right parts.
Hardened pushrods, Comp 918's, and go for the Titanium Retainers.
For extra piece of mind go for dual springs instead of the 918s.
