Spun 5 and 6 after rebuild
Old 09-17-2009, 11:37 AM
Kus99TA's Avatar
Default Spun 5 and 6 after rebuild
I rebuilt my engine and after 1,000+ miles I had metal in the oil and a knock. After tearing it back down I found #5 and #6 rod bearings spun. The rest of the bearings looked good,other than some metal going through the motor. When I rebuilt it I had the crank turned and replaced most everything. Eagle rods,Wiseco pistons,LS1 oil pump,roller timing set,cam,lifter,pushrods,etc...everything new. My question is what would cause 5 and 6 to go? Will a 6.0l crank work in my 5.7 block?
Old 09-17-2009, 11:41 AM
MelScrilla's Avatar
It might have been clearence issues when installing the main caps.
and yes a 6.0 crank will work in a 5.7
Old 09-17-2009, 11:56 AM
01ssreda4's Avatar
Did you check clearances during the install or did a shop do it?
Old 09-17-2009, 12:00 PM
eric1h's Avatar
how was the oil pressure? #5 seems to be the one affected most by lack of oil.
Old 09-17-2009, 12:29 PM
Kus99TA's Avatar
I checked the clearance's when I assembled it and everything was good. Oil pressure was good too,gauge showed almost 60 at idle but as the noise came the pressure dropped,before I pulled it out it still had 30+ hot at an idle.
Would 5,6 be affected by oil press first or 7,8 since they are furthest from the oil pump?
Old 09-17-2009, 01:32 PM
Monte4ever's Avatar
Was the clearances too tight? I've read some other post where the clearances were set on the tight side (.0008-.0012) which is within GM specs for a production engine. However, many has complained that those clearances proved to be too tight when building for higher HP and RPM. If you had 60psi hot oil pressure and 30 when things let go, I'll say they were on the tight side.
Old 09-17-2009, 03:15 PM
Kus99TA's Avatar
On the rods I had .0015 clearance,apparently I need to run .002
Old 09-17-2009, 09:07 PM
01ssreda4's Avatar
So the rods were too tight?? Did you use a stock replacement bearing or what?
Old 09-17-2009, 11:45 PM
novaflash2002's Avatar
.0015 isnt too tight. ive put a couple of ls series together with only .001 and they are still running fine.how did no3 main and no 4 main look?
Old 09-18-2009, 06:51 AM
Kus99TA's Avatar
Everything else looked GREAT....of course there was a little metal in the other bearings but none of the other rods or the mains had any signs of wear.
Old 09-18-2009, 12:02 PM
Monte4ever's Avatar
Some people have problems with tight clearances after mods are done and some don't. .0015 is well within GM specs, but I would not want extra tight clearances on the rods or mains after rebuilding it for higher HP. From what I've read you can set the mains up at .0015 because the aluminum constructed block will increase the clearance by about .001 when brought up to operating temps. However, the rods will not expand as much, therefore I would try to set them at .002 minimum. Let me point out that I'm in NO WAY a professional engine builder but a home hobbyist that has built a few SBC's and BBC's. I'm new to the LS family so maybe I can learn something here also. What type of RPM was you turning?
Old 09-20-2009, 09:13 AM
Kus99TA's Avatar
I understand where you are coming from, I can't count how many engines I've built (I use to own a machine shop) but the LS motors are a little dofferent. I'm looking to turn it about 6,500.
Old 09-20-2009, 10:57 AM
KCS
Moderator
KCS's Avatar
Did you use plastigauge or a dial bore gauge?
Old 09-20-2009, 11:56 AM
Monte4ever's Avatar
6500 is not that high for an LS based motor.
Old 09-20-2009, 12:24 PM
ChucksZ06's Avatar
I would say that the clearances were to tight. When clearances get tighter everything has to be perfect as far as roundness etc. That is why you can get by with tighter clearances sometimes. The looser clearances also let more oil through which helps keep the bearing cool. Bearing metal is very soft.
Old 09-20-2009, 05:58 PM
elias_799's Avatar
60 psi oil pressure seems allot on an ls1 oil pump, i have a meling 296 and i have 55 psi idle. and that's a high volume/high pressure pump.
anyway, i think the high oil pressure was giving you a sign that the bearing clearances are too tight.
Old 09-20-2009, 06:48 PM
HCCH's Avatar
Your clearances were a little on the tight side. I'm not saying that there is no way they could survive that way but I wouldn't set the rods that tight. A good rule of thumb is to have .001" of clearance per inch diameter of the journal. The LS1 has a 2.100" rod journal so .0021" clearance would work for most applications.
Old 09-20-2009, 08:48 PM
Kus99TA's Avatar
Dial bore gauge
Old 09-21-2009, 09:14 AM
Old Geezer's Avatar
"Eagle rods"...
What was the side clearance on that throw??
Old 09-21-2009, 11:01 AM
yea also with a looser clearance it lets the oil squirt out of the bearing quicker too.
