What the f%&k is this plug?!?!?!?!
Location: Home town Clive,IA current town FORT BENNING GEORGIA
Alirght guys me and my buddies just put my bbk ssi intake on everything seemed to go as planned untill we found this plug and have no idea where it goes to. http://s622.photobucket.com/albums/t...t=100_1689.jpg obviously its the white plug with the blue holder.
thats what i thought it was too!!!!! but we tried starting it and the car would either die idle rough like 500rpms for a minute then die. how bad can installing an intake manifold through off your tune? i dont think its a vacumm leak i was told they make your car idle like 2k plus.. if it makes it any better the wire is on the left side of the intake by the break booster on the middle of the wire harness, we tried using my buddys 2000ss he had a place to clip his in but doesnt run egr or air?
how do i know the intake is on all the way, i mean its on but when we went to put it on when the bolts where on and not snug the intake had alittle bit of play but when we tighten them down it the intake became flush with the heads. is it a vacuum? i guess when my buddy started the car he had to keep it gased for it to turn on then he said he disconnect the tps sensor and the car turned on but it didnt idle right it always stayed below 2000 rpms
If you're not sure if it seated properly the best thing to do is pull it off and put it back slowly and carefully. But I would think if it was a leak that it would rev or have an unsteady idle rather than low. Make sure all your injectors are seated properly and harnesses are connected. Also make sure your map sensor is in and sealed, make sure the big hose in the back isn't pinched or in a bind.
last question, hahah how bad would the tune through it off the car was previously tuned for my set up with my stock ls1 manifold, now that i have the bbk could that cause it to not want to start without me feathering it, when i started it today i feathered it for about a minute then it held its own idling at about 500rpm then i gased it and it dropped to 200rpms jumped to 400rmps and then died, could it be the tune?
damn it the reason im trying to get so much info is because im not used to efi cars, so then what should i do i dont understand why the hell my car wont start everything is hooked up? man i hate these cars sometimes...
is it possible that you hooked ur coil harnesses up backwards? I hooked my driver side coil pack harnesses up backwards and my car barely fired up and ran like dog **** and spit and popped....so i immediatly knew it had to be the coil harness by process of elimination....an intake swap doesnt really have to much depth to it that would cause ur car to run like you are saying, either you fucked up your map sensor during the swap or ur injectors, or ur coils I would assume...good luck
You said the bbk intake had a little play before you tightened it down? These intakes come with a single buttonhead bolt for the valley cover because they hit on the passenger rear side. If you did not replace this bolt you may be sucking air in on your passenger rear side runner... Just food for thought.
