what cams work with ls6 springs??
Old 09-18-2009, 09:10 PM
txh0tb0i972's Avatar
LS1Tech 10 Year
Default what cams work with ls6 springs??
just wondering if there are any other cams other then the ls6 cam and hotcam???
Old 09-18-2009, 09:29 PM
maxspeed96ct's Avatar
I did alot of research on this just because I was worried about the task of changing the springs. (it took some time but wasnt that bad )
theres a Few cams that "might" work with the LS6 springs, But I honestly Wouldnt risk it.
You can buy a set of patriot duals with titanium retianers for $255 and be worry free .
You wont know if the springs will work untill you pop one, but then its to late...
Old 09-19-2009, 01:57 AM
cellulis44's Avatar
the yellow ls6 springs a pretty damn stout for a stock spring.
just stay around 550 lift and you should be golden.. I would trust a LS6 over a 918 ANY day...
Old 09-24-2009, 10:57 PM
LS1Tech 10 Year
so any other cams other then the ls6 and hotcam?
Old 09-24-2009, 11:07 PM
I Like Gold!!!
BBLS1's Avatar
i ran 222/224 566/568 112 with those springs. No problem
Old 09-25-2009, 10:46 AM
5_02ls1's Avatar
ran a vinci 220/224 551/551 on the green yellow striped ones with no issues....
Old 09-25-2009, 11:47 AM
11 Second Truck Club
MPFD's Avatar
I think Z06 springs are pretty durable but they don't have much seat pressure. I ran 'em with my old 212/218 lowlift setup, with no problems.
Old 09-25-2009, 11:55 AM
180ls1's Avatar
the asa cam will, that cam makes great useable power for being older and having a low lift. with any cam you are going to want to keep it under .570 lift and you are going to want a mild ramp rate.
Old 09-26-2009, 11:16 AM
Hector's Avatar
Let your cam choice determine your spring choice. The other way around is a bit goofy.
