Port and Polish heads PLEASE???????????
Was up guys hey i have a ?. When u get your heads done do you need to get your intake manifold done also. I got the Ls6 intake and there 243 heads. I was leaning more toward stage 1 p&p Thanks Guys
LS1Tech Premium Sponsor
We offer cnc porting, valve job, milling, decking & reassembly for $600!! Here's the specs:
http://www.texas-speed.com/shop/item...d=649&catid=20
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
We can do the 5.3L heads as well as the LS6's (243 or 799). And of course, we do all of the LS3/L92 and LS7 heads as well if someone has cores they want ported (prices vary).
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
