threw a rod now what?
Old 10-21-2009, 09:45 PM
texas_ss's Avatar
Default threw a rod now what?
ive had my 01 ss for about 3 years it had 1300 miles when i bought it and currently has about 47k when the engine went, dont know what happend havent pulled the motor out yet to see extent of damage but there is a whole in the block so im thinking about builing my own problem is im kinda indecisive and dont know what to build or what block to start with. it will be my first build but i have oil in my blood so help wont be far away, im just asking for yalls opinions
Old 10-21-2009, 11:04 PM
conan's Avatar
Goals and budget ?
Old 10-21-2009, 11:11 PM
supersick99z's Avatar
383! 383! 383!
Old 10-21-2009, 11:27 PM
02*C5's Avatar
buy a 408 cheap and the possibilities are endless with that engine.
Old 10-21-2009, 11:38 PM
texas_ss's Avatar
the car was a dd but after the build it wont be i was leaning toward 383 but like i said im indecisive and 408 is in the back of my head if i did the 383 should i use the ls2 block? 408? goals are not clear i dont take it to the track and it def. wont be a track car weekend worrior. hp goal prob around 500 to 550 and possible forced induction in the near future. budget at the moment around 5k but not limited to
Old 10-21-2009, 11:50 PM
+badss+'s Avatar
get a forged 408
Old 10-21-2009, 11:51 PM
+badss+'s Avatar
dont bother with the 383 for the lil extra cash you can build a 408 and be happy dont look back
Old 10-23-2009, 02:36 AM
Unertl42's Avatar
LS7? Who doesn't want one........................Seriously
Old 10-23-2009, 03:37 AM
TransAmcoupe98's Avatar
408 is definitley a bad *** motor, but If your block is ok, and I'm sure it is, just get a stroker kit(383) with forged rods, pistons, etc. If you are planning on going forced induction, how long down the road will that be because it will play a role in how you are building the engine. A used set of TFS or AFR's along with a nice custom cam could get you your goals of 500whp. For around 5k....maybe
Old 10-23-2009, 08:26 AM
Intercooler2's Avatar
I doubt he can use that block if it has a hole in it... agreed?
Old 10-23-2009, 08:37 AM
01ssreda4's Avatar
Hole in the block = destroyed
Old 10-24-2009, 03:28 PM
texas_ss's Avatar
haha yeah the block is scrap aluminum at this point and i am leaning to a 408 most likely ill buy a short block and go from there 408 plus procharger sounds like a beast but also sounds really expensive
Old 10-24-2009, 08:12 PM
G Engines's Avatar
don't buy a off the shelf short block. You may spend a little more money but it will be well worth it to have a reputable shop build it. I just completed one for $ 5300 included head studs and head gaskets. Calies crank & rods je pistons with a new lq9 block
Old 10-24-2009, 09:45 PM
conan's Avatar
A 408 would be a good choice. If your going to go forced induction decide before you choose your pistons.
http://www.texas-speed.com/shop/item...id=46&catid=28
Old 10-24-2009, 10:46 PM
BlownChevySS's Avatar
540 with twin 102mm's!!!!!!!
Old 10-25-2009, 01:22 AM
stevied916's Avatar
jb weld works wonders
Old 10-25-2009, 01:25 AM
stevied916's Avatar
decide what you are doing in the end for sure before building a block. no point of driving around with a 9.0:1 motor and never putting forced induction on it. I pieced together my d1 kit. It saved me thousands over new but if it's you dd then there is no way this will ever happen. Front mount turbo should be considered if you're serious. Just remember at that power you're going to be spending money on the trans, rear and suspension too...
Old 10-25-2009, 02:33 AM
SO DO BUBBLE GUM AND DUCT TAPE BUT DON'T TELL ANYBODY
Old 10-25-2009, 10:06 AM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
Without a doubt a 408 would be a great option for the $$$. We have them on special currently!! The 408 is probably the best bang for the buck combo you'll find. You could run any number of head combos with that setup & it will grow very well with you. I've built everything from 600hp 408s to 700hp 408s depending on how aggressive you want to get!!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 10-25-2009, 11:23 AM
SweetS10V8's Avatar
Clean it up and put a glass table top on it. Youll have a nice converstation piece.
