sliding in the lifter dowels? condensor is giving me trouble
Old 11-04-2009, 06:14 PM
ae13291's Avatar
Default sliding in the lifter dowels? condensor is giving me trouble
hello, im trying to slide in the lifter dowels i have made, the rod length is 22" excluding the handle. is this too long? the condensor is in the way right now. should i cut the rods just a bit? i want to lift up the condensor but then i would be lifting it way too much since the holes in the block are above the camshaft
Old 11-04-2009, 06:50 PM
vettenuts's Avatar
The cam itself is around 21" so you may have an issue that needs to be fixed before going further unless the handles you refer to lengthen the rods. Are they just bend 90 degrees?
Old 11-04-2009, 06:58 PM
ae13291's Avatar
thanks for the reply, the straight rod itself is 22" and i made a 90 degree bend at the end which is 3" long so should i cut them 1 inch or 2 inches? how else do other people put in the rods? the total rod length before the bend is 24"
Old 11-04-2009, 07:04 PM
blue99fbody's Avatar
i had someone just twist the condenser up out of the way or hook it to you hood if alone and i think my dowls were around 24 25 in but i just used brake line cut to length
Old 11-04-2009, 07:29 PM
ae13291's Avatar
ok, i have to make sure they slide in completly straight right? and is it the passenger side that needs to be flat a bit or the drivers?
Old 11-04-2009, 08:00 PM
ya they should slide in without much force and i didnt have anything flatened but a buddy used my dowels and said he had trouble getting one in one side but it went right in the other but i cant remeber what side?
Old 11-04-2009, 08:08 PM
Benner's Avatar
okay I'm having a brain fart or something right now. What are we talking about "Dowels"
Old 11-04-2009, 09:35 PM
to hold the lifters when doing a cam swap^^^^^^^
Old 11-04-2009, 10:14 PM
Benner's Avatar
Okay. I was having a blank moment. Thanks
Old 11-04-2009, 10:31 PM
eseibel67's Avatar
You need to lift the condensor up out of the way to get the cam out anyway, so move it.
I don't see the problem here once the condensor has been moved. You will be moments away from removing the cam.
Old 11-04-2009, 11:29 PM
ae13291's Avatar
yea i understand, but for the dowels i have to lift the condesor even more because the holes are higher then the cam. but anyways im going to get my brother to help me because i was doing it myself. thanks guys
Old 11-05-2009, 02:53 PM
eseibel67's Avatar
Good idea. You could tie it up if your on your own, but the easiest way is to have someone hold it.
