buy 243's or get mine ported?
OK ive been trying to decide what to do for awhile now.. I know its time to upgrade the heads on my car and i wanna know the best way to go about it is. i wanna know if i should pick up a set 243's and get them ported or if i should just take my 853's to get ported? I plan on spending about $800. So if i get the 243's for about 400 and spend another 400 on porting will they outflow my 853's if i just spend 800 on porting those? the flow numbers im shooting for are 300+cfm on the intake side and 230+cfm on the exhaust side. Can 853's even be ported to flow that much? full details please
i know people are going to say just save up and buy TEA's or AFR's or PRC's, but i can get some 243's for pretty cheap and i really kinda wanna do this as an experiment.
keep in mind, i have NOT looked up porting prices, i know they are expensive but im just trying to get a feel for which direction i should head. If 800 wont get me the numbers i want( im pretty sure it wont) thats fine, then disregard the price ive put on it.
243s will out flow and out perform 241s. I know this because I fought this battle. I had a set of 241's ported, deck milled .030, and 59CC chambers. I went with a different set of heads, 243s, cnc, ported, deck milled .005 and standard 64CC chambers with the same cam I gained 20rwhp with a larger cam I ended with 450+ rwhp on an A4 so that should tell you what a difference 243's make.
This is on an LS1 engine w/ over 80K on the clock.
LSX Mechanic
If I was in this situation I'd take a 243 casting, cut a good valve job in it, do a good blend, deck them .015 and put it on the car. You can get this all done under $1000 (including the price of the heads) and have more compression than a 5.7L head, more piston/valve clearance.
I've done a couple of cars with 243's done the way I described, a custom cut cam, and normal bolt ons making 430-440rwhp with a nice flat TQ curve.
Your best bet is to just save about $200 more and buy a set of CNC ported 243s. Texas speed starts with new castings, flow what you want, and are like $1025.
http://www.texas-speed.com/shop/item...d=649&catid=20
having someone port your heads isnt a good idea unless they flow them before and after to prove they didnt screw up their heads.
