engine rebuild with a cam
Old 11-07-2009, 09:12 PM
ryanp502's Avatar
Default engine rebuild with a cam
hi out there, im in the process of rebuilding the ls1 out of my 98 ss m6, i plan on putting in a better cam but im having trouble finding information about the best cam to use with the stock heads.
Old 11-07-2009, 09:28 PM
ae13291's Avatar
you should get the heads ported or atleast get some 243's or 706 heads since you are building the motor.
Old 11-08-2009, 04:42 AM
ryanp502's Avatar
yeah im pretty budgeted so even though i would like to buy some new heads i think im going to do some port work on the heads instead
Old 11-08-2009, 10:43 AM
BaddBird's Avatar
DD? Strip? What are your goals for the car?
Old 11-08-2009, 02:41 PM
ryanp502's Avatar
its my daily driver, but it will see a few runs at the track
Old 11-08-2009, 02:57 PM
SiL3NtXWS6's Avatar
224/228 or 224/230 is something along the lines of what I would look into if i was you.
Try to keep it about 2-4 degrees of overlap.
Old 11-08-2009, 04:14 PM
ryanp502's Avatar
hey thanks everyone but ive decided to go another route
