Ls1 Build
Ls1 Build
I was just wondering what head gasket to use on my Ls1?
I'm putting Ls2 heads, rods and cam on it. I'm also replacing the intake and throttle body. I have a FAST 90-90 set-up.
I have the gaskets for the TB and will be buying the valve cover gaskets, timing chain gasket and timing chain as my car has about 114k on it. I also planned on replacing the lifters.
Also if i should be replacing anything else or do anything else to it?
Help...........
Help...........
LS1Tech Premium Sponsor
GM MLS gaskets would take care of you, or we also offer the Cometic gaskets which you can get thinner gaskets to tighten up the quench.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Use the standard 3.910" gaskets. They'll be perfect!
__________________
