High oil pressure - stock ls1
My oil pressure was usually around 40psi until about 2 days ago. When the engine is warmed up to about 200 degrees I now have about 50psi at idle and about 60psi at 2000rpm. The engine is not making any weird noises or behavior
What would cause my oil pressure to be higher than normal?
I plan to change the oil and filter on Friday just to rule that out. Any suggestions on what brand sythetic I should go with?
You need to verify oil pressure changes with a mechanical gauge. I just checked mine recently bc I thought I had low pressure. Turned out to be the replacement sending unit from oriellys is whats at fault. Pressure is great, its just reading low. Bought an oil pressure gauge kit from harbor freight for $16. Then I tapped the port above the filter with a 1/8 NPT thread.
1 Post
when liquid travels from a large hole to a smaller hole that is velocity decrease and pressure increase. dont you think the pump has to work harder to force through oil into the filter? after the pump the oil goes to the filter. i installed one of those high milage filters on my car and i was running 65 psi on idle ( i know the stock gauges are inaccurate but it still shows) so think about it
1 Post
when liquid travels from a large hole to a small one the pressure doese increase, but if the hole opens up again to the original size then the pressure would be lesser than that of the starting pressure because of the restricion. the sensor is after the oil filter or the restricion. So it would read a lower pressure if or less flow if the filter was restrictive. Correct me if im wrong. so higher pressure would mean higher flow.
im sorry i dident explain, if you havent seen the inside of those high milage filters they have a plastic block that will let the oil flow to the sides instead of straight down into the filter. i understand what you mean by the oil pressure sensor, yea its after the filter, but there is 2 holes for the oil filter adapter one goes in and the other will shoot straight to the oil pressure sensor. but i understand what your saying, i know when the fuel filter starts to clog on some GM cars the fuel pump will get louder, yes its under more stress but the pressure stays the same. i know for a fact that oil filter made my gauge read a much higher psi.
1 Post
There is only one hole feeding to the filter and one leaving to oil everything else. The hole that comes from the filter then splits... You cant just squirt oil towards the oil pressure sensor. Only solution is if your seeing more psi, you are getting more oil and have less of a restriction. It is more than just the shape of the filter it is also what the filter material is made of. Cirtian matierals can filter more and restrict less.... It just depends how much you want to spend.
frams dont flow very well.... that is why most suggest a mobil 1 filter, wix, or purolator pure one. they flow better and increase your oil pressure by up to 10 psi. Im not sure what high mileage filter you used but they probably made it out of better materials to give the engine more oiling since it has so much wear.
