Just finished heads/cam install
Old 12-15-2003, 09:05 AM
Kevyn's Avatar
Default Just finished heads/cam install
I finally finished installing the PP stage 2 5.3 heads, TSP 231/237 cam, lifters, pushrods, jwis tining chain, asp pulley and hooker cat back.
A few observations...
- Next time (if there is a next time) I need to do this indoors or when it's warmer out
- The TSP 231/237 cam idles better than my old hotcam.
- The hooker cat-back cured the rasp from my MACs and former 2OTL
I just got a couple heat cycles done yesterday and noticed the exhaust is tapping my floor (no biggie). If it dries up, I'll take a little shakedown ride today.
I would have never taken on this project if it was not for the help of this board and ls1info.com. Thanks!
Old 12-15-2003, 03:37 PM
deviate42's Avatar
congrats
now the fun begins!
have you had the car on the dyno yet? a good tune is what you need next
Old 12-15-2003, 04:31 PM
Kevyn's Avatar
I haven't been to a dyno yet. I may have to wait 'till after the holidays before I do.
Old 12-15-2003, 05:08 PM
jrp
SN95 Director
jrp's Avatar
you did do an oil pump swap didnt you? i've done a head swap and 2 cam swaps so i know the what you just got done doing
Old 12-15-2003, 06:16 PM
Kevyn's Avatar
I put a ported Katech oil pump oil on when the hotcam was done in 2001. It only has about 15k on it so I'm hoping it will last a little while longer. I did, however, install a JWIS timing chain.
The bolt that holds the pickup to the pump was the scariest bolt of the whole job.
Old 12-15-2003, 06:21 PM
jrp
SN95 Director
jrp's Avatar
gotcha . and on the ****** oil pick up tube bolt. thats something only someone who's done there own oil pump swap can understand.
Old 12-15-2003, 06:31 PM
HOTROD98Z's Avatar
Nice setup man, what kind of numbers are you hoping for out of that combo?
Old 12-15-2003, 06:39 PM
Kevyn's Avatar
I would be real happy with anything over 400 rwhp.
The reason is that both the decent tuning shops around here use a Mustang dyno which (from my understanding) is good for tuning but doesn't give as high of numbers as the dynojets.
Old 12-15-2003, 07:36 PM
HOTROD98Z's Avatar
Yeah that would be good being that you will be on a Mustang dyno, i beleive the mustang is usually about 10% lower than the Dynojet. Did you have any problems along your install, i am looking at doing my install within a couple of months and just wondering how it went for you. Hey by the way do you have any soudclips of that cam?
Old 12-15-2003, 07:49 PM
jrp
SN95 Director
jrp's Avatar
whats his face 02floridaSS or something or another :o has clips. sounds . and as long as you follow jmx's guide you should have no problems.
Old 12-15-2003, 07:55 PM
Kevyn's Avatar
I don't have any sound clips of my car yet but I found this thread in the multi-media section.
With the hooker cat back I still get a nice lope but it's a lot quieter than this guys duals.
Old 12-15-2003, 08:08 PM
HOTROD98Z's Avatar
Yeah i've heard his setup, was just curious to how it sounds through a y-pipe setup. That cam does have a nice lope to it, imagine it on a 110lsa.
Old 12-15-2003, 10:09 PM
Mike98WS6's Avatar
Sounds like a nice set up. You should be over 400 rwhp.
