When do you need shorter pushrods?
Old 12-15-2003, 10:14 PM
StupidFast's Avatar
Default When do you need shorter pushrods?
I am going to have a set of stock LS1 cut 30 thousandths and install a Comp 216/220 cam. Do I need shorter pushrods? Will I have trouble with the intake? Thanks alot.
Old 12-15-2003, 10:20 PM
9 Second Club NA
Dragaholic's Avatar
You will need pushrods .030 shorter than your stock pushrods. The amount you shave off the head, the same amount must be taken off the pushrods.
Old 12-15-2003, 10:38 PM
Spinmonster's Avatar
If the base circle of that cam is smaller, you will not need to use shorter pushrods. Call the vendor you bought the cam from.
Old 12-16-2003, 01:03 AM
strokedls1's Avatar
If you take 30 off the heads, and the cam base circle is 30 under the you just use 7.400 pushrods (stock length) If the cam is a standard base circle then you would go with a 7.350 push rod, and shim up the rocker for proper lifter preload.
Old 12-16-2003, 11:54 AM
white2001s10's Avatar
What happens if you don't have enough lifter preload?
I measured preload on a bone stock 98 and got .150"
That seems very excessive.
Is there some reason why the LS1 lifter needs this much?
Old 12-16-2003, 02:56 PM
2001CamaroGuy's Avatar
most cams have a 0.030" smaller base circle which would make up for the 0.030" mill. My TR224 was an example of this.
Old 12-16-2003, 03:18 PM
killer01ws6's Avatar
What about a TR230/224.
stock heads, stock PR right?
Old 12-16-2003, 03:53 PM
Nickn20's Avatar
stock lenth is fine for that cam and stock heads
to the poster of this thread if you find out your base circle of you cam is too big, I have some hardened pushrods for sale 7.25 in lenth PM me
Old 12-16-2003, 03:58 PM
Tin Indian's Avatar
Well, get a set of Thunder Racing / Comp Cams 7.40" hardened rods. They are actually .015" longer than stock. [Stock rods are actually 7.385" long].
That will put you within about .010" - .015" of the stock spec with your non-milled heads and aftermarket cam..... No problem at all.
Old 12-16-2003, 04:05 PM
What if I have already got a set of molly 7.40s coming( from a board member)
new in box... Do i need to sell them and get a set from TR??
Man I hate when I should have asked before I buy
Old 12-16-2003, 04:23 PM
Tin Indian's Avatar
Killer ...
I think your hardened pushrods are more than likely made by Comp Cams.
Get a set of calipers and mic them yourself. If you can't get a mic, any machine shop will mic one of your stock rods and one of your new rods for free.
I will bet your new rods are .015" (15 thousands) longer than the stockers.
Ron,
Old 12-16-2003, 04:30 PM
Just testing to see if my post is invisable.
Old 12-17-2003, 08:22 AM
My suspicions are confirmed. Oh well, at least I can see it.
Old 12-17-2003, 08:24 AM
Ron I was hoping to get some input about your opinion on this, but any others are welcome as well.
Old 12-17-2003, 09:30 AM
Did someone hear something??
J/K
I don't know the answer on preload....
Old 12-19-2003, 03:11 PM
Killer ...
Ron,
Well My pushrods came in today,
they are manleys, 7.40 #4130 swedged end, proseries..
SO are these true 7.40 and will they be good with my TR230.
Thanks,
Pete
Old 12-19-2003, 04:41 PM
strokedls1's Avatar
You just need to put them in and see how many turns it takes to get 22 ftlb. The stock lifters use a lot of preload, but most after market require only 1/4 to 1/2 turn for proper preload. Contact the manufactuer if you want exact preload specs.
Old 12-19-2003, 06:09 PM
Tin Indian's Avatar
Like I said, put a mic on one of them along with one of your stock rods and see what the difference is.
Really very simple indeed. No mic? ... Any machine shop will do it. Takes about a minute.
Quick Reply: When do you need shorter pushrods?
