what head gasket do i use?
Old 12-22-2009, 02:17 PM
monte383sbc's Avatar
Default what head gasket do i use?
i have a 98 ls1 and iam installing prc #243 ls6 2.5 heads, iam searching around and some places say theres notches on certian heads? iam looking for a .050 mls gasket any help would be appricated thanks matt
Old 12-22-2009, 02:21 PM
streetassasin's Avatar
http://texas-speed.com/shop/item.asp...d=879&catid=36
http://texas-speed.com/shop/item.asp...d=602&catid=36
Old 12-23-2009, 12:41 AM
radchevy's Avatar
I have a 2000 block and currently changing heads. I checked the thickness of the stock gaskets and I get 0.059 after they were used.
Old 12-23-2009, 05:53 AM
69LT1Bird's Avatar
Compressed thickness of GM LS1 head gaskets is 1.33 mm or .052"
Old 12-23-2009, 09:33 AM
Jon@Texas-Speed's Avatar
You can run a GM MLS gasket or a set of Cometic head gaskets. The GM thickness does vary a bit. I usually find them around .054" thick. If you want closer to .050" thick, we have the Cometics on the shelf in a 3.910" bore, .051" thick. Let me know if we can help!
Jon
Old 12-23-2009, 03:16 PM
radchevy's Avatar
How much comp can be gained by reducing the thickness by 0.010?????
Is it worth the extra 50 dollars to go to 0.040's
Thanks
Old 12-27-2009, 11:23 PM
thanks guys for all your help
