Did LQ4/9 head bolt questions...
Old 01-06-2010, 10:18 AM
ss.slp.ls1's Avatar
Default Did LQ4/9 head bolt questions...
Are LS1/6 and LQ4/9 cylinder head bolts the same? Did the LQ4/9 blocks switch to all short bolts in '04 like LS1/6 blocks did?
Old 01-06-2010, 11:38 AM
SUCK MY SS's Avatar
they are the same as the long/short ls1 bolts up until 'o3... in '04 they all made the change over to short bolts.
Old 01-06-2010, 11:39 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
Yes, they got the change over in '04 as well
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 01-06-2010, 12:01 PM
ss.slp.ls1's Avatar
Another question...
LS1 heads + 6.0 block = needs 6.0 gaskets?
6.0 heads + LS1 block = needs 5.7 gaskets?
Old 01-06-2010, 12:54 PM
claytonisbob's Avatar
6.0 gaskets.
Old 01-06-2010, 01:09 PM
ss.slp.ls1's Avatar
Originally Posted by claytonisbob
6.0 gaskets.
For both?
Old 01-06-2010, 01:15 PM
1SLwLS1's Avatar
Originally Posted by ss.slp.ls1
For both?
yes, accommodate for the larger in whichever engine combo.
Old 01-06-2010, 01:40 PM
ss.slp.ls1's Avatar
Figured that much, just wanted to be sure.
Old 01-06-2010, 07:10 PM
LSxPwrDZ's Avatar
I always match the gaskets to the bore. Even though the 6.0L heads have a slightly larger chamber for the bigger 6.0L bore there is still going to be an edge there due to smaller bore cylinders whether it's part of the gasket or part of the sleeve.
Old 01-06-2010, 07:16 PM
ss.slp.ls1's Avatar
I thought that would just burn the gasket...
Old 01-17-2010, 07:36 PM
LSxPwrDZ's Avatar
If the gasket is MLS it's not going to burn it. The only thing mix matching parts like this is you need to make sure the compression part of the gasket is between the head and deck surface to provide a seal. Heck I'm probably going to use the LS3 gaskets on my 4.005" bore TFS235 head motor even though the LS3 gasket is 4.065" just so i can make use of the 5 layer gasket vs the 3 layer of previous years. Havent really decided yet.
After rethinking this situation a 6.0L gasket would probably need to be used since the bore is just over .100" difference between 5.7L and 6.0L. The head might not seal using the smaller bore gasket on a bigger bore head.
Old 10-12-2020, 10:54 AM
Dqe2767's Avatar
Default Lq4 2003
Would the 03 block be better in that case?
Old 10-12-2020, 02:06 PM
Received 3,024 Likes on 2,355 Posts
Better to have all one size (late block) for consistent torqueing, but it really makes no difference in the long run.
Quick Reply: Did LQ4/9 head bolt questions...
