Miss under load only, idles fine, but no codes??
Hey guys I was out driving my Datsun Z (see sig for specs) yesterday and my fan relay died without me knowing so the car started to overheat once I got into some traffic. Soon as I got moving again it leveled off but I noticed it started to miss while under load (even a light load) and there is a noticeable loss in power during accel.
If its in neutral it idles and revs just fine, but soon as I place it in drive and load the motor a little while applying the brakes it will start to miss.
I checked for codes with my hand held scanner and there are none pending or stored. I started to worry about a possible head gasket failure, but there is no water in the oil or oil in the water. There is no unusual valvetrain noise either, but I haven't pulled the valve covers yet to check for sure either.
Tonight I went ahead and yanked all the plugs and all of them looked great except for #5 which looks like its starting to fowl. While I had the plugs out I figured I might as well check the compression on #5 which gave me 180 psi. I tested #1, #3, and #7 too and all were within 1-3 psi from each other.
So at this point I am thinking maybe it overheating was just a fluke and its either #5 spark plug, #5 plug wire, or #5 coil pack (all original factory stuff from 2005).
I bought another set of spark plugs, but the store was out of plug wires until Monday. I will go ahead and put the plugs in the morning and try my luck.
Any other suggestions on what it might be?
Thanks guys!!
Thanks guys!!
Still, I have an extra set of injectors that I can try if all else fails.
Could you see the crack in your plug after removing it?
I would be happy if mine ended up just being a bad plug too, but my luck usually isn't that good.
Thanks!!
1 Post
I considered an injector being the issue, but you'd think the plug wouldn't be fouling and smelling like gas if the injector was dead or dying.
Thanks!!
Thanks!!
1 Post
after driving close to 100 miles i had a check engine light come on for 2 minutes and it turned off by itself. it came up for a #4 cylinder misfire. i was pretty thank full for that light coming on because i changed lots of things trying to find the problem, i even hallowed out my cats thinking it can be clogged.
Had the same symptom, miss under load only with no codes. Ended up finding a small tear on one of the spark plug boots ( MSD wires ), seemed to leak voltage under load. Actually saw it arc under load.
