dual springs pros/cons. tell me which ones yall perfer
Old 12-20-2003, 01:16 AM
taqwache's Avatar
Default dual springs pros/cons. tell me which ones yall perfer
i am on the market for some dual springs and cant make up my mind. they need to fit in the stock seats without machining the heads. i can only find 5 that will work.
1. comp cam 921s (expensive but probably the best)
2. crane LS1 dual springs (cheaper but not sure on quality)
3. rev dual springs (havent heard anything on them)
4. patriot dual gold springs (too new and not sure yet)
let me know what yall think i should use. i need to buy some soon. i just got my new cam in and am not taking a chance on the 918s with the new motor. please help i cant make up my mind.
Old 12-20-2003, 03:16 PM
c5jonny's Avatar
I have the TSP 231/237 cam on the way and am going with the cranes, good to .650. I dont forsee any problems, if any one else wants to chime in and share some expiriences good or bad I would appreciate it.
Old 12-20-2003, 03:42 PM
Viper's Avatar
I'm running Isky 295D's, and they seem to be working fairly well. They work without machining but are not a true dual.
I just found this thread too:
https://ls1tech.com/forums//showthre...eferrerid=1805
Old 12-20-2003, 04:16 PM
taqwache's Avatar
what do you mean there not a true dual. are they a single spring with a damper? also are the rest of these springs true duals or do they also have dampers?
Old 12-20-2003, 06:22 PM
JDPZ28's Avatar
Crane duals here with about 1k miles on them and no problems yet(knocks on wood)
Old 12-20-2003, 07:55 PM
jrp
SN95 Director
jrp's Avatar
what are your cam specs? i ran my tr230 with the rev duals no problem. havent heard any problems with the comps 921's or the cranes. i know gomer is running the new patiot duals i believe. he seems to like them.
JoSeY's Avatar
Rev duals... my cam has .600 lift on both lobes and EX-R lobes and I've had them for over 10Kmils...plus, they're quiet!! imagine that....
Old 12-20-2003, 09:56 PM
taqwache's Avatar
its going to be a .602 lift and will see 7000rpm. looks like alot of people are useing rev springs. how much are those?
Old 12-20-2003, 10:37 PM
jrp
SN95 Director
jrp's Avatar
bout 350 for the whole kit; dual springs, tit. retainers, and spring seats. you'll need new vavle stem seals, you can get those from TR for 16 bucks. i dont know what kind of duration or the kinds of ramps your running but i'd spring for the 921's or comps.
Old 12-20-2003, 10:49 PM
LS1Tech Sponsor
Slowhawk's Avatar
I run Cranes on my .600 lift cam with no problems.They haven't been out long enough to see how long they last.
Old 12-20-2003, 11:16 PM
HOTROD98Z's Avatar
Anyone running the Comp 977's
Old 12-21-2003, 01:31 AM
I can shift faster than you.
Jason99T/A's Avatar
If you have the money, go with the Comp 921s. If not, the Crane duals would be my next choice. I have used both on quite a few customer's car without any problems.
Jason
Old 12-21-2003, 11:18 AM
MASS seller approved
Time2Kill's Avatar
I've got Comp 987s which are a dual spring, and after 10K miles on a .608/.612 cam, I'm losing almost 50 hp in my upper RPMs from my springs going bad.....
Old 12-21-2003, 08:43 PM
99 Black Bird T/A's Avatar
Received 1,432 Likes on 992 Posts
Time, I didn't think the 987's were rated to go over .600 lift?
I have 987's but only a 224 XE-R cam, so far no problems with 6,000 miles. I may plan on changing them out sooner now.
Old 12-21-2003, 10:53 PM
taqwache's Avatar
whats the talk about the comp 977s. do they need machining to fit and how much do they cost?
Old 12-21-2003, 11:44 PM
Jason99T/A's Avatar
The Comp 977s or 987s will not fit in the stock spring pocket. I personally would run the Comp 921 or Crane duals before the 977/987s anyways.
Old 12-22-2003, 09:05 AM
Time2Kill's Avatar
Ive been doing some research on the 987s and it looks like they are only good up to a .590 lift. Kinda pisses me off because I told TEA what size cam I was putting in and they still gave me these springs.
Old 12-22-2003, 09:45 AM
JF WS6's Avatar
What's kind of strange is that it seems some of the older batches of 987's seem to be holding up a bit better than some of the newer ones with these aggressive XER cams. I have a Comp XER cam with about the same lift as you intake/exhaust and although I don't have that many miles on them I haven't experienced any float at all so far..... although honestly I don't completely trust them so they will be coming out when my heads are freshened up.
These are on a set of heads Jay at Absolute did for me over a year ago. I know he's recently this year had some problems with float on the 987's, but he even told me himself that some from the older batches seem to be holding up fine. I just thought this was unusual is all....
Old 12-22-2003, 11:46 AM
killer01ws6's Avatar
I have a set of the Patroit duals on the way going in with my Tr230.
I will keep you guys updated.
Old 12-22-2003, 12:11 PM
CHRISPY's Avatar
I am swapping out my 987s for 977s this winter (Running comp R lifters is a must with these springs and aggressive cam lobes)
