ms4's favorite head?
i have done some searching to see what head best matches the ms4, I havent found much. looking for the perfect head to match my ms4 and fast 90/90
There are a couple options you can look at depending on your budget. We can get you setup with a set of Stg.1 LS6 heads. They would be the most budget friendly head that will clear without flycutting the pistons. If you are looking at aftermarket castings, we can run a set of the PRC 215cc or 227cc small bore heads. These will probably be the best head you can put on with that cam and will not require the need to flycut. They come out of the box with PRC EHT .675" springs and you can run factory rockers if you would like. Both heads are proven to make great power when matched up with this cam. The same heads have been on our heads/cam record car the last 2 years at the LSX Shootout!
Jon
Jon
LOL^^ it depends how the tech guys feel !!
About the calongo statement, everything can be modified or adapted along the way..though I dont have the exact context of the thread.
The best is to have a kinda final goal for the setup. I say the cam tells what kind of setup(DD, torque, track, etc..) you really wants; about the heads, its a $$ question, because everyone would running big dollar heads if not.
One of the problems with good advice is that it may not be what one wanted to hear. That doesn't make the advice bad.
"There are some people who, if they don't already know, you can't tell 'em."....Yogi Berra
Jon
You actually got very good advice. That's not necessarily the case in this thread.
Jon
Jon
