Push rod length for my cam?
Old 01-20-2010, 11:14 PM
ethan071891's Avatar
Default Push rod length for my cam?
Im going to be running a 228r cam in my 02 z28 with stock 241 heads, and i dont have a length checker and thought someone might know.
Old 01-20-2010, 11:29 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
7.400 would be fine for that cam. Those heads aren't milled are they? You say stock, but I was just checking. I ran 7.350's on 0.050 mill and never had an issue.
Old 01-21-2010, 12:24 AM
Ok thanks for the info and no they aren't milled.
Old 01-21-2010, 06:16 AM
DUSTYWS6's Avatar
I'm running 7.425" pushrods on my 228r with stock heads and head gaskets and have no valvetrain noise. 7.40" are good for most aftermarket cams with stock heads, but the 228r has a smaller base circle then most which warrents the use of the 7.425" pushrods. Before I did my install, I bought a pair of digital calipers and measured each lobe of the stock cam and 228r and ran the numbers to conclude that the 7.425" was the right length to get near stock lifter pre-load.
Old 01-21-2010, 09:07 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
If you're not going to measure, 7.400" would be the best guess for that XER lobe on a completely stock long block.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
