243 heads
Old 01-21-2010, 09:20 AM
00 black ss's Avatar
Default 243 heads
I'm wondering what applications the 243 and 799 series head came on I was planning to go to local junk yards but need a list of the applications they are on
Old 01-21-2010, 09:24 AM
Jon@Texas-Speed's Avatar
243's cam on LS6 vettes, 05-07 LS2 vettes, 05-06 GTOs, and even the new 5.3L trucks have 243 casting heads. 799's came on some later LS2 motors as well as the trucks. That should get you a pretty good vehicle base to start with.
Jon
Old 01-21-2010, 06:59 PM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
Don't forget we also offer brand new 799s fully assembled for $450!!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 01-22-2010, 12:32 AM
tspence45's Avatar
Is that with stock valve springs, or aftermarket ones? I may just take that route with my new 6.0, for now.
Old 01-22-2010, 01:00 PM
the 799 is the same thing as the 243
Old 01-22-2010, 01:03 PM
King Nothing's Avatar
is it?
Old 01-22-2010, 01:06 PM
NAVY99B4C's Avatar
it is?^^^
Old 01-22-2010, 01:25 PM
02*C5's Avatar
Originally Posted by King Nothing
is it?
Yes I have seen the 799 go for a ridiculous low price on ebay. At least 2 sets south of $400.
Old 01-22-2010, 06:29 PM
same flow and everything as a LS6 243?
Old 01-22-2010, 11:27 PM
02*C5's Avatar
The 799 heads are in fact an LS6 casting. They list part no. 12564825 for the 01-04 LS6 engines and the L33. The L33 takes its cylinder heads from the LS6. Originally developed for the Z06 Corvette, these heads improve airflow in and out of the engine. With their pent-roof combustions chambers and new flat top pistons (the pistons in other Gen III Vortec 5300s have a slight sump in the piston deck), the L33’s compression ratio increases from 9.5:1 to 9.9:1. This increase improves the engine’s volumetric efficiency yet still allows it to achieve full power with regular grade gasoline. They have a D shaped exhuast opening. The heads have a 65cc combustion chamber and a 210cc intake runner.(Silver05GTO 2007)
http://forums.corvetteforum.com/c6-t...experts-3.html
Old 01-23-2010, 12:59 PM
BaddBird's Avatar
Look for a 04 and up grand prix gxp or a impala ss with a 5.3 LS4 they came with 243s.
Old 01-23-2010, 01:10 PM
so the 799 flow the same as the 243s? ill just pick up a set of those for at least 150 cheaper
Old 01-23-2010, 02:31 PM
no1izspeshl's Avatar
Yeah 799s are the virtually the same as 243s. The only upside to ls6 heads were the fact they had sodium filled valves on z06 vette heads. Otherwise as far as the head itself 243 and 799..same thing.
Old 01-23-2010, 02:36 PM
yarrie's Avatar
Anybody know what the 243's flow, and the comparison between the 241's and 243's?
Old 01-23-2010, 02:39 PM
yarrie's Avatar
I just picked up some 243's off an 5.3 truck, and was wondering if they were the same as the heads on the ZO6
Old 01-23-2010, 02:45 PM
**** i might just buy some 799's. do the sodium filled valves even make a difference performance wise?
Old 01-23-2010, 02:53 PM
I am sure there is a performance aspect to it all, but from what I have read it helps with a lighter valvetrain. I am thinking for the higher rpms the ls6 was a capable stock. I could be wrong. If so someone will correct me.
Old 01-23-2010, 03:06 PM
you can change out the valves correct?
Old 01-23-2010, 03:10 PM
nevermind
Old 01-23-2010, 03:28 PM
02*C5's Avatar
wait wait wait i don't need a lighter valvetrain beings that cam i'm using has some pretty aggressive lobes
That's when you want the lighter valve train. The less weight the less wear over all on your lifters and so on. Set up with the correct springs it should be good to go. My cam if from Ed Curtis very aggressive lobes and I have the LS6 valves/Gaterman Ls1 lifters/comp 921 springs purrs like a kitty. My heads where done by AI and running 64CC chambers.
http://www.youtube.com/watch?v=8SLz1a2BwSE
241
Stock Head Flow Numbers
Chamber 66.67 cc------0.100--0.200---0.300---0.400---0.500---0.550--0.600
Intake 200 cc------------67----122-----178-----215-----219-----223---227
Exhaust 70 cc------------52-----97-----133-----156-----170-----76----180
243
Chamber 64.45 cc-------0.100---0.200--0.300--0.400---0.500---0.550---0.600
Intake 210 cc------------62------126----184----224-----251----256----257
Exhaust 75 cc------------57------108----143----163-----176----180----183
