Torquer v.2 Cam what Valve Springs & pushrods
Old 01-23-2010, 05:59 PM
2002sscamaro's Avatar
Default Torquer v.2 Cam what Valve Springs & pushrods
i just got a camaro that has stock springs but has a texas speed torquer v.2 cam what springs and pushrods should i buy any help would be nice thanks
cam spec's 232/234 .595/.598 Camshaft
motor is
6.0 lQ4
stock 241 heads
Old 01-23-2010, 06:34 PM
Restricted User
Zero4488's Avatar
Comp 918's or PRC Gold Springs...either would work well with that cam...
Old 01-23-2010, 07:50 PM
SweetS10V8's Avatar
It would help if you give the specs, the stupid name doesnt mean anything.....
Old 01-23-2010, 07:54 PM
badss_02's Avatar
beehives and set of hardened chromoly's (stock length) im pretty sure...
Old 01-23-2010, 07:55 PM
badss_02's Avatar
Old 01-23-2010, 08:02 PM
06blackGTO's Avatar
sorry the torquer 2 cam is a 232/234. 595/598 112LSA. I run the same cam.
I would call tsp and order there dual spring cam kit. that come's with everything you need. Since the cam is from tsp. But it really doesn't mattter where you get them, but I would go with a dual coil spring and hardened pr's.
Old 01-23-2010, 08:07 PM
BaddBird's Avatar
Originally Posted by badss_02
232/234 595/598
Fixed
Old 01-23-2010, 08:08 PM
badss_02's Avatar
Yeah My bad that is what i meant on the duration, I was thinking of a grind i'm looking at. Lol
Old 01-23-2010, 08:09 PM
badss_02's Avatar
That cam is not aggressive enough for it to be necessary to run dual springs... It would be smart though.
Old 01-23-2010, 08:21 PM
BaddBird's Avatar
Pac 1518 beehive good to .650 lift and measure for PRod lenght.
Old 01-23-2010, 08:22 PM
MUSTANGBRKR02's Avatar
Patriot duals and order the PR length checker and order the correct length the first time.
Quick Reply: Torquer v.2 Cam what Valve Springs & pushrods
