Stock main journal size?
Old 01-24-2010, 04:29 PM
blacksi's Avatar
Default Stock main journal size?
Trying to get bearings to fit my crank. Does anyone know what the stock main journal size is?
Old 01-24-2010, 05:02 PM
RARON455's Avatar
according to my GM service manual,,,
crankshaft connecting rod journal diameter 2.0987 in. (production)
crankshaft main journal diameter 2.558-2.559 in. (production)
manual calls for
.0006-.00248 connecting rod bearing clearance (production)
.0007-.00212 crankshaft bearing clearance (production)
Hope this helps
The following 2 users liked this post by RARON455:
Homer_Simpson (11-30-2021), Sway Tale (11-03-2020)
Old 12-25-2014, 10:50 PM
csmc711's Avatar
4 years later it did for me, thanks!
Old 07-19-2015, 08:12 AM
Blazeracer's Avatar
^^^^ One year after this guy, it did for me too. Thanks. These kinda threads are great. Short, sweet and to the point.
Old 07-19-2015, 11:54 AM
Know It All's Avatar
I guess you guys missed the sticky at the top? The one with all the clearances and dimensions...
Old 09-14-2015, 11:00 PM
csmc711's Avatar
All board members bitch to use google and search the answer, well, google gave me this, so, you need to go yell at google, Mr KNOW IT ALL!!
Old 09-15-2015, 09:07 AM
Bruh...did you forget to take your meds or something? Yell at Google? I didn't say anything about using Google. Just below the button you press to start a new thread is a sticky titled:
LS1/LS6 Engine Dimensions & Clearances
You don't even need to use Google, or start and even bump a thread like this, when the answer is permanently posted on the first page...but obviously some people are not that attentive...
Old 09-15-2015, 05:18 PM
csmc711's Avatar
I was looking for journal size in google and this thread came up first in the search. Apparently you dont know how google works, you should check it out sometime because you dont "know it all".
And, still again, this thread helped me out, thanks raron.
Old 09-16-2015, 09:07 PM
Are you really this dumb? Or are you just bumping this thread to troll?
When I search LS main journal size, the sticky I reference is THE NEXT thread to come up. So my point still stands, this was a dumb thread to start since the answer is stickied to the first page of this section.
Old 10-23-2017, 09:01 PM
Bobby Kelii's Avatar
I did the exact same thing, google stock lm7 5.3 connecting rod bores and widths and this was one of the suggested links. Thanks to the original poster 🤙🏽
Quick Reply: Stock main journal size?
