What valve springs and retainers?
Old 01-27-2010, 11:45 AM
malibutwins's Avatar
Default What valve springs and retainers?
I have a XER287HR comp cam I am putting in a lq9 with 243 heads Comp doesn't show what springs to use with this cam. any help would be great. Also if i run this cam straight up will I have enough piston to valve clearance?
Cam specs are 605/609 238/240 on a 112 lca. Oh and what lifters?
Old 01-27-2010, 01:33 PM
02*C5's Avatar
My cam is a bit bigger over all same LSA and I am running comp 921s. On new stock LS1/LS6 lifters got them from Gaterman Products $100.
Old 01-27-2010, 01:36 PM
teke184's Avatar
comp 921s should do the trick no prob.
you can use stock retainers or go aftermarket if you want a little lighter valve train...and lighter wallet
Old 01-27-2010, 03:47 PM
SOMbitch's Avatar
You have a myriad of choices.. Just make sure they can handle your lift and are set at the proper installed height. That is just as important as choosing a well matched spring...
Lifters- Morels ar Lunati are awesome but on a budget LS7's will work just fine.
Old 01-27-2010, 08:04 PM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
The all new PRC valve springs are a ground up replacement to the gold/platinum spring kits that's been around for several years. The PRC .650" spring kit will easily handle what your looking to do & was designed to provide a longer spring life & resist losing spring pressure. The spring kit is priced well under $300 & offers springs, titanium retainers, seats & seals.
If your wanting to go single springs & don't mind changing springs more often, you might checkout the PAC single springs. We sell them as a package with free new valve seals for $150!!
http://www.texas-speed.com/shop/item...=1064&catid=48
.650" kit
http://www.texas-speed.com/shop/item...d=173&catid=48
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 01-27-2010, 10:16 PM
SweetS10V8's Avatar
26926s is what I would put on mine if I had that cam. I dont think I would run any single beehive type of spring on that much duration.
People think Im crazy for running 918s on my 219/235 .607/.621 cam, and I wouldnt run them on anything much bigger..
Old 01-28-2010, 08:29 AM
I would like a spring set that needs no machining
Old 01-28-2010, 09:21 AM
99blancoSS's Avatar
http://estore.websitepros.com/2120533/Detail.bok?no=62
Set of PAC 1518's will do the job, direct drop in replacments, some people prefer doubles, but they require a seat and seal change. You have the PAC 1221 and 1521 if your looking to go with doubles as welll as the PRC's and Patriot golds.
Old 01-29-2010, 01:53 AM
Wicked94Z's Avatar
its not the duration that determines spring requirements, its the lobe profile
Old 01-29-2010, 06:32 AM
SweetS10V8's Avatar
If you want to be technical, its the system as a whole that determines spring requirments and setup.
And very few of us have he ability to test on a spintron, so we generalize based off of experience.
I would still go with a set of 925s or 926s and add the tool steel retainer.
Old 01-29-2010, 09:21 AM
Why not titanium? Also what stall should I have for this cam? It's in a 5500lb truck with a small 150hp shot. Right now I have a circle d 245mm 2c.
Old 01-29-2010, 03:37 PM
cam
cam's Avatar
Patriot golds and LS7 lifters
Old 01-30-2010, 09:14 AM
Ok here is what I would like to go with..... Dual springs with titanium retainers that needs no machining. Looks like patriot gold kit FTW!!!!!!
Old 01-30-2010, 09:23 AM
What pt # 8401 or 8401-b ? What part number for a 243 head?
Old 01-30-2010, 09:25 AM
223HAWK's Avatar
Patriot golds simple as that.. Good product..awsome service..
Old 01-30-2010, 10:00 AM
SweetS10V8's Avatar
Originally Posted by malibutwins
Why not titanium?
Because Titanium wears away and is more expencive, tool steel retainers are typically within 2-3g of Titanium and dont wear.
I weighed my tool steel retainers and they were within a gram of the Ti.
Old 02-13-2010, 08:07 AM
hymey's Avatar
Patriot extremes would work nice, 155 pound seat pressure and take 660 lift plus very light retainer and good locks. Full kit for like $275. Throw a new set in every 15000 miles.
Quick Reply: What valve springs and retainers?
