Need some help with my fuel setup on my HCI project
ok well here is the HCI setup im getting ready to install on my 2000 TA
ported 241
236/240 654,609 111lca
pacesetter LT's
TSP ypipe
magnaflow exhaust
4400 stall
3.73 gears
Weiand Manifold
PP TB
and maybe some nitrous in the future(not 100% sure yet on this)
what type of fuel set up am i going to need.... as of right now i have nothing stock everything
i was planning on getting some svo green top injectors(42lb), will they be sufficient or are they too big, also what fuel pump set up should i go with(racetronix, walbro, etc) or stock pump should do?
ported 241
pacesetter LT's
TSP ypipe
magnaflow exhaust
4400 stall
3.73 gears
Weiand Manifold
PP TB
well as of right now im going to leave the nitrous out of this whole situation
if i was going to spray it would be a wet 100 ( stock 95K bottom end)
awesome thanks guys.... also should i do the hotwire kit or just leave it as is, i have a fuel pressure gauge to monitor it but i dont want to test the water with low fuel pressure
