Reuse of stock con rods?
They say there good to 500+ i belive. anyone correct me if im wrong.
i reused mine and havnt had any issues. the rod bolts are the weak link. Buy ARP's and forget about it! You can run it to the moon........almost.
I am doing a build right now on mine, reusing rods and pistons... Just make sure to keep you rods and caps together, yes they are cracked which means the rods and caps have to go back the same way they came apart.
Number your rods and caps so you know they will go together the right way. I also bought the Arp 2000 bolts from what i here they actually strenthen the rod, dont know if its true but i do know rod bolts are a problem and the Arp's should help out alot.
Because the bearing spinning in the rod will open up the inside diameter and the heat generated by the friction distorts the shape. It is common practice to machine the mating surface of rod and cap then hone the ID true. But because a cracked rod does not have a machined surface where the rod and cap meet this can't be done.
this is not true at all bro. not being a dick but they CAN be resized/honed depending on how out of round it is. an oversize thickness bearing is available. do a search on here youll find out.
thats true...but like he said....he spun one. its cost effective to resize. sometimes you dont even have to use a thicker bearing shell. they can machine just enough off the cap faces that they still match up and resize the rod depending on how non-concentric the journal is. its done all the time.
I'm not trying to be argumentative here, but you can not machine the faces of the mating surfaces on a cracked rod. There are no dowels to align the cap, it is held true by the jagged surface left by the cracking process. Machining the mating surfaces will remove the fractured surface and allow the cap to move around on the bolts.
