ARP head studs, rod bolts, head gaskets
Putting together a motor, nothing huge, factory 346 ls6 cam ls6 heads gunna get a 100 shot and wondering which head gaskets and head stud kit i should use?
LS1Tech Premium Sponsor
What year is your block? That'll make the difference as to which of the ARP kits you can use. As for head gaskets, we have had alot of success with the Cometics when the surfaces are properly prepped (block and heads). They offer them in the thinner compressed thickness too, so you can get the benefit of a bump in compression as well as a tighter quench which helps ward off some detonation!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
__________________
i know thinner gaskets will make more compression but will i have any clearance issues? also i need an oil pan gasket, you guys sell them? i called but the phones seem pretty backed up.
With an LS6 cam you can run the .040" gaskets and still have PLENTY of piston to valve clearance!
__________________
