PTV with MS4, Pics inside
Well I recently spun a bearing, when pulled the motor apart, I found PTV contact on every cylinder. This is the first time ever pulling the heads off, or even being in the motor besides the cam swap. I was revving the stock bottomed end to 6800. What do you think caused it? Car was MS4 with dual springs and a 150 shot.
Kev D
Kev D
I thought that the ms4 was to big for stock heads? Im probably wrong but I thought that the ms3 was the biggest they made for stock heads. I dont think that he measured either. He could have over revved the car also and it would do that wouldnt it?
looks like valve float to me since the exhaust valves contacted the piston. the reason for that is because the exhaust valve is closing as the piston is coming up and if the valve springs are weak/overreved then contact is likely.
