compression test results
Well I had one done on my forged ls6 with je pistons with -2cc reliefs
Heads milled .050 59cc chambers
About 4 1/2k miles on engine
170 on 6 and 165 on 2 cyclinders
My question is about the numbers, Is the -2cc reliefs causing my compression to be lower and if so by how much? I see most with this setup minus the pistons like 190ish? I also have a tr230 if that matters.
Originally Posted by Joe DIESO
Ummm.... Why don't you just call Don and ask him, do you think he's stupid or something?
Originally Posted by wrencher
The cam will affect static compression.
Was the motor warm ? How many miles on the motor?
Hi,
I estimate about –0.29CR for 2cc notches from 0CC’s.
Your setup is + 0.74 over stock 66.67 head, 0 CC’s with same deck & gasket.
If you went from an early gasket to a late gasket it would be –0.22CR.
Didn’t JE raise the deck? Is the cam setup retarded?
Good luck,
Steve
Good luck,
Steve
Originally Posted by SNW Vette
Hi,
Good luck,
Steve
Good luck,
Steve
