Why L92 heads won't fit LS1/6 UPDATED!!
I haven't seen any "proof" as to why they won't fit...so I thought I would post my own. I don't know if anyone will find it interesting, but I did...plus I got bored . Here are a few pics up the cylinder. It's kind of hard to tell from the pics, but I'll explain after the pics.
UPDATED....see post 22 overbore=open valves.
It's not the giant intake valve that is the problem. It's actually the exhaust valve that hits. The pictures are of stock L92 heads milled 20 on a stock bore LS1 (with no head gaskets). Both valves are open quite a bit also. You might be able to notch the side of the cylinder to allow the exhaust valve to fully open...it doesn't lack much. Now once it's all bolted together, I don't know if there would be any issues with the intake valve, but as it sits it fits. So there you go. They fit, but they don't.
Now the combustion chambers are obviously big bore also...so there is another problem.
I'm curious as to why anyone would want to install them on anything less than a 4.0 bore. According to many people "in the know", even if it were possible to run these heads on a standard bore LS1, you'd be losing power due to a BIG loss of efficiency.
I agree with a na setup...but what about a forced induction like turbo/supercharged setup??? I would think that it would be able to hold more compressed air than something like a 243 head therefore making it more effecient and the smaller bore size would make it even more efficient at higher rpms...your thoughts???
I can appreciate the posted pics, just for curiosity reasons. There's a reason why GM made a 6.2L block and put these heads on top of it. They simply have to have a bigger bore than a 5.7L. I believe that even with a 4.0" bore, the exhaust valve is still shrouded enough to leave power on the table...
I really found that interesting too. I would have though of the intake valve being the obstruction. I seen on the Edelbrock website that you needed to notch the sub 4 in bore to use the L92 head, and now you have the proof. Now I know it is big far as motor size due to valve shrouding, but I am kinda curious to see a dyno run what the curve might look like.
Here is the equation that most people use:
MORE AIR+MORE FUEL=MORE POWER
Those are some nice pics. How did you get in there to take those pics? Do have hands like the burger king tiny hand guy?
I don't know if they would actualy run very good, but it's interesting to see. Notching the block may not be impossible, but it looks like it would be in the ring area of the piston. I'd make it work and run it if putting an engine in was as easy as changing your clothes and I happend to have a spare block with L-92 heads sitting around.
