500hp possible on stock LS1??
Like the title says do guys you think 500hp is possible with a stock ls1 short block.I was thinking of boosting my car but I changed my mind and am sticking to all motor and selling my nitrous kit.So my question remains on the 500hp mark for a stock ls1 bottom end or whats the highest youve seen so far?Im barely getting back on the ls1 game again so I have slight knowledge for engines but not too much then again thats why people ask right?Thanks for looking
Hope that helped..
Hope that helped..
The stock bottom can hold up to around 600Rwhp and that is where you better start saving your pennies for a new bottom end.
500hp is easy..
You were told correctly. The money it takes to make a real 500 and have it be dependable would be better spent on a 408 short-block.
People wind engines up to the hilt and de-stroke due to class restrictions.
If you want 500 rwhp and have it be street-able.. you increase your cubic inches. Heck we've seen solid rollers make 540 but I wouldn't want it in my car. There is that formula floating around where the guru used lsx lobes ( the lobe of craze at the time).. I heard his engine blew up a few months later but I don't think you see that in the sticky
I think 500 NA would cost you every bit as much as say 550 with a procharger.
The cost difference between 450 and 500 on a 346 LS1 seems to be huge. 450 can be done with ported 243's and a big cam. 500 requires expensive aftermarket heads with custom camshafts and expensive valvetrains to meet the demands of the cam lift.
tech doesnt always tell you the rest of the story
http://www.airflowresearch.com/artic...le083/A-P1.htm
if you use tfs 215 you get +20 cfm
+15 to 20 wrhp mean About 500 wrhp
that was 2005 !!
that was 2005 !!
450 seems more likely to me now. Dont know if ill reach it but I have set my mind for a set up Let me know If I can improve on something from the list below.
TSP PRC 215cc CNC heads
TSP MS4
FAST 92MM AND PORTED
KOOKS 1 7/8 headers....
What would be the best chamber size on the heads or keep it 62cc and on the cam What LSA 111 or 112??? Im asking you guys since I dont want to order something thats wrong and its always better having a second opinion.Once again thanks
TSP MS4
Heres A thread from a while back. Remember all this was done with stock rear end. Oh, and this was done with the Tsunami cam which is about 4 degrees smaller in duration than the MS4
https://ls1tech.com/forums/dynamomet...e-results.html
TSP MS4
TSP MS4
Spraying=112 N/A=111
Call TSP and ask them. That is their heads and their cam, they will know best. That is a KILLER setup.. Same heads/cam used on the record breaking stock bottom H/C camaro. I have my own opinion but I would think TSPs would be better, or at least I hope! TSP knows their ****!
