prc h/c package on lq4
what kind of power number would i be looking at with this kit http://texas-speed.com/shop/item.asp...d=832&catid=47 with a Tv2 cam 112lsa on a stock bottom end lq4? what compression ratio? looks like a great set of heads to make my 450rwhp goals with.
how about the 5.3's to get the compression up. http://texas-speed.com/shop/item.asp...d=203&catid=47 this should put me in a better compression ratio range and they flow about the same as the ls6 heads
kinda outta my budget. will be in the 86 monte. single plane vic jr., 780cfm quickfuel superstreet, hedman longtubes, 3 inch header back pypes duals with x pipe and cutouts. 3.73 gears 3200 stall.
LS1Tech Premium Sponsor
We've had the LS6 stage 2.5 heads & TSP camshaft make 100rwhp gains before. Do you have a baseline dyno run? The LS6 heads & Torquer 3 or Tsunmai would be a great option.
If you were looking to spend more on aftermarket castings we have some great options for the smaller camber/little bit bigger runner guys. I have PRC 227 heads with 62cc chambers!!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
with the t3 cam would it keep me in the 3200 stall range, would it work better with the ls6 or the 5.3 heads, and how about lsa would i need to have it custom ground to work better with the carb?
