Fuel For St2 Heads and TSP231/237 ?
Im going to be installing PP st2 5.3s and either a TSP 231/237 or a TR230/224 and i was wondering if i need to upgrade my injectors and fuelpump as well as i will be nearing 410-440rwhp?
Would Motorsport #30 do? if i have to and what about a 255 inline pump?
LS1TECH Sponsor
i dont think its a necessity but it would be good piece of mind to start upgrading your fuel system at that point...figure youd be in the 420-440hp range which is upon the brink of needing upgrades...id say get the stuff on and get dynoed...see what the a/f ratio is and go from there.
lata
Bill
lata
Bill
Thanks for the info i just figured if i had the car apart i might as well give myself peice of mind on the fuel system. Anyone running 440RWHP with stock fuel system?
LS1TECH & Trucks Sponsor
You'll be just fine running 440 RWHP with the stock fuel system in your '01. You do have the larger 28.5# fuel injectors. I certainly would not recommend running any nitrous on top of 440 RWHP N/A with the stock fuel pump, but you'll be fine if you stay N/A. We have installed numerous heads/cam setups pushing 440+ RWHP with the stock fuel system on the '98, '01, and '02 cars. If you had a '99 or '00 car, it would be a good idea to step up with a larger injector.
Unless you are planning on stepping up with more engine down the road or pushing a dry shot of nitrous, you'll be just fine with your stock '01 injectors. A 255 lph in-tank fuel pump wouldn't be a bad idea for some growing room down the road, though.
Feel free to give us a call if you have any questions about your fuel system or our 231/237 camshaft. The regular price on our 231/237 is $360, so it's pretty hard to beat!
Matt
Texas Speed & Performance
Matt
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Would an inline down the road be ok , i would rather not mess with install a intake. I though 98 was only year to have 28.5s and all 98+ had 26 im not sure just asking?
Also how is drivability with a good tune on the 231/237? Its a daily driver that sees the joys of stop and go traffic from time to time?
One last thing ZO6 cluth good/ bad for this H/C combo wont do much racing, how much would a Spec St 3 cost for clutch,PP,flywheel?
Thanks all for the help
An inline fuel pump will help some, but an in-tank will be a better setup to give you more growing room. The '01 and '02 LS1's went back to the larger injectors, so you do have the 28.5# injectors.
The drivability with the 231/237 is great with proper tuning. One of the co-owners, Trevor, ran that cam in his '02 SS automatic, and he did not have any drivability issues with tuning. It started perfectly on cold and warm starts. You just have to like a lumpy idle.
The ZO6 clutch will definitely be on borrowed time with a heads/cam setup. The SPEC stage III clutch has worked well in the heads/cam setups that we've installed here, and quite a few of them have put down over 440 RWHP.
Matt
Matt
__________________
Cool thanks for the help, didnt know about the injectors (makes me feel a little better) Ill probably be ordering the cam from you guys pretty soon could you PM me a price for Spec St3 clutch,pp,flywheel?
Also what pushrod length for the PP st 2 5.3s not milled?
Originally Posted by 01PewterWS6
Allright thanks gomer
Yella Terras?
Yella Terras?
